Changing my transmission fluid.
Discussion in '1st Gen. Tacomas (1995-2004)' started by josh.., Nov 24, 2009.
  1. Nov 24, 2009 at 6:40 AM
    josh..
    josh.. [OP] Well-Known Member
    Sarasota, Florida
    '02 SR5 V6 4x4 Double Cab
    K&N drop-in air filter, body lift.
    I did search and saw that this has been gone over about a million times, but I couldn't really find the answer I was looking for. I'm trying to go about changing my important fluids and want to do the transmission and differentials. I see that it's going to take 75W-90 in the front and rear differential and the T-IV fluid from Toyota for the transmission. My one question is it best to just drain and fill the transmission, or to actually get it flushed? I know it would probably be dependent on how dirty it is, but I'd rather just do it myself than have to start it and then go get it flushed somewhere.
  2. Nov 24, 2009 at 6:43 AM
    98tacoma27
    Ben
    Not Beech Creek
    I would just drain and refill.
  3. Nov 24, 2009 at 6:52 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    X2.
    Depending on the condition, maybe do it again in a few months.
  4. Nov 24, 2009 at 8:07 AM
    L8ight
    L8ight Active Member
    Brad
    Ft Walton BEach Fl
    2002 Tacoma SR5 V6
    I was told by a Toyota service writer that you only want to drain and refill, NOT FLUSH. He said that all the ones they drained and refilled, were fine; of the ones that got flushed, most came back with issues.
  5. Nov 24, 2009 at 8:08 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I have heard the same thing. But from people that have had the trannys flushed.
  6. Nov 24, 2009 at 8:16 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    i drain and fill every 15k
  7. Nov 24, 2009 at 8:42 AM
    josh..
    Sarasota, Florida
    Alright, sounds good to me. And it takes around 4 quarts?
  8. Nov 24, 2009 at 9:05 AM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    i think about 3.2
  9. Nov 24, 2009 at 9:29 AM
    Fly5465
    Fly5465 Well-Known Member
    Gilbert, Arizona
    02 4WD TRD
    36,000 miles
    Chris or others,
    When you say you do a drain and refill, do you just drain at the plug or do you drop the pan? Also, do you recommend changing the filter? I have a 1st gen 02 with 36,000 miles. Probably never been done.
    Thanks,
    Fly5465
  10. Nov 24, 2009 at 9:34 AM
    josh..
    Sarasota, Florida
    Just drain at the plug.
  11. Nov 24, 2009 at 9:37 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I useually pull the pan, clean the screen, then reinstal and fill.
  12. Nov 24, 2009 at 9:54 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    First thing you want to do is Botch your oil change, from there...
  13. Nov 24, 2009 at 9:55 AM
    josh..
    Sarasota, Florida
    I've already changed the oil twice. Just been lazy getting around to doing the rest.
  14. Nov 24, 2009 at 10:00 AM
    jackal
    jackal Well-Known Member
    in a life of monotony
    07' TRD Sport
    Grillcraft, TRD CAI, Icon remote resis, deavers, AR mojaves, Snugtop Supersport
    i just did this last weekend. drained at the plug then realized there was no dipstick so pulled the pan down and filled. per the dealer its 3.2 liters to refill. cleaned the pan, didnt touch anything else.
  15. Nov 24, 2009 at 10:01 AM
    98tacoma27
    Ben
    Not Beech Creek
    First Gens are a different beast.
  16. Nov 24, 2009 at 10:04 AM
    jackal
    07' TRD Sport
    I wasnt talking first gen. he's got an '09 and i've got an '07
  17. Nov 24, 2009 at 10:05 AM
    kilted1117
    kilted1117 I smell corn
    Gophuk Yousef
    Valparaiso, IN
    2013 Tacoma SR5 4dr Magnetic Grey
    Zippo.
    :eek: My '02 has almost 160,000.
  18. Nov 24, 2009 at 10:06 AM
    kilted1117
    Gophuk Yousef
    Valparaiso, IN
    Zippo.
    Don't worry, I got the joke! :rofl:
  19. Nov 24, 2009 at 10:09 AM
    98tacoma27
    Ben
    Not Beech Creek
    Thought you were referring to the OP.
  20. Nov 24, 2009 at 10:15 AM
    jackal
    07' TRD Sport
    I was talking about the OP, he's got an '09 right? am i missing something?:confused:
