Changing O2 Sensors
Discussion in '1st Gen. Tacomas (1995-2004)' started by yotapower10, Jul 23, 2009.
  1. Jul 23, 2009 at 3:59 PM
    yotapower10
    yotapower10 [OP] Well-Known Member
    Neal
    Virginia
    02 Tacoma SR5 4x4 TRD
    TJM Roo Bar(Front Bumper/Bull Bar), LED Stop/Turn signal, LED undercab/bed lights, Custom Sound System w/ Subwoofer, Spray-In Bed Liner, Deck Plate mod, Black emblems, Black Stock Rims, Custom Fishing Rod Holder
    I just got a new O2 sensor and I went to start changing it out on my 02 v6 taco and apparently the nuts were too hot to put any torque on them because now the head of the bolt is rounded off....awesome
    what can i do to get the bolts out to change the sensor? I cant get any real big tools in there because of course its the one right before the cat and its in the most awkward place....atleast i hope its the right one
    The code was for an O2 sensor bank 1 right 1 or something and the guy at advanced told me it was the first one starting from the engine going to the tail...the code was p1135
    any help would be awesome
  2. Jul 23, 2009 at 4:01 PM
    dman597
    dman597 Well-Known Member
    Doug
    maryland
    2012 DC 4X4 SPORT w/Tow
    6" Pro Comp Lift,295-75-R17,access rollup,Tint,front hitch,nfab step bars
    visegrips?
  3. Jul 23, 2009 at 4:02 PM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    Vice grips, if that didn't work, then Weld a rod across the top of it. thats what i did i had the same problem as you
  4. Jul 23, 2009 at 4:04 PM
    yotapower10
    Neal
    Virginia
    well i dont have a welding machine and i dont have my vice grips with me theyre 2 hours away :( any other ideas?
  5. Jul 23, 2009 at 4:06 PM
    dman597
    Doug
    maryland
    well what do u have with u
  6. Jul 23, 2009 at 4:15 PM
    WhatThePho?
    Andre
    HCMC, VN
    2006 STi
  7. Jul 23, 2009 at 4:16 PM
    yotapower10
    Neal
    Virginia
    pretty much 2 sets of metric set of wrenches (both without a 12mm and 11mm of course i need a 12mm), a crescent wrench, needle nose pliers, a hammer, a 5 pound maul, wd 40, and does bein pissed off count for anything??? haha
    i guess im gonna have to go buy another 12mm and some vice grips because itll be next week before i get any time to change it
  8. Jul 23, 2009 at 4:18 PM
    yotapower10
    Neal
    Virginia
    ive already tried the pliers that i have and i forgot about the other pliers i have i forgot to mention that i didnt know if there were any tricks someone knew to getting out stripped bolts
  9. Jul 23, 2009 at 4:20 PM
    dman597
    Doug
    maryland
    i use vice grips realy tight
  10. Jul 23, 2009 at 4:21 PM
    yotapower10
    Neal
    Virginia
    ok thanks for yalls help ill go buy some other ones to keep in my truck thanks a lot +1
  11. Jul 24, 2009 at 3:57 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    You need to run to the store and buy some stuff....Spray it with PB Blaster and let it soak.
    Vise Grips or get a file so you can file the edges off and 'square up' the corners again so you can get a wrench on it.
    It's always a good idea to work on your truck when you have access to a good set of tools. Because even the simpliest jobs can turn into a nightmare.
  12. Jul 24, 2009 at 5:09 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    X2 on the PB blaster. Let them soak for a while.
  13. Jul 24, 2009 at 8:50 AM
    yotapower10
    Neal
    Virginia
    i cant believe i didnt think about pb blaster my dad uses that stuff all the time at home...thanks ill make sure i get that done this weekend as of right now my sensors still stuck on there but ill make sure i get it off soon thanks for the help
