CHANGING OIL 1st TIME on my '05 TACOMA, 14MM socket
Discussion in '2nd Gen. Tacomas (2005-2015)' started by adrianm2627, Feb 24, 2011.
  1. Feb 24, 2011 at 1:05 PM
    adrianm2627
    adrianm2627 [OP] Member
    California
    05 PreRunner V6 SR5
    Hello All,
    I have come to the unfortunate end of my pre-paid maintenance (50,000) since I first purchased my vehicle.
    I do have problem though. I bought the OEM filter to do my oil change. I read that a 14mm will do the job for letting the oil out, and so far it does fit.
    However, the Toyota Techs must have used some power tool to tighten the bolt to where it is nearly impossible to undo. It is so tight that the socket keeps slipping off.:mad:
    Has anyone had this problem? The tool that I have is not great, so I definitely want to invest in a tool that is strong enough to undo it, at the same time I don't know much about them. The tool I have appears to be a short wratchet handle that is "5.5 inches long. The socket is 14mm and 2 inches long. This tool has seen better days.
    Can anyone recommend anything that will untighten the Toyota Tech's deadly grip without having to spend more days setting up an appointment and waiting?
    Any input will be appreciated.
  2. Feb 24, 2011 at 1:07 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    Use a cheater bar on the end of the socket handle or a 14mm wrench
  3. Feb 24, 2011 at 1:08 PM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    try a six point short socket...and a longer handle
  4. Feb 24, 2011 at 1:10 PM
    Toyotacrawler
    Toyotacrawler She's got the jimmy legs
    Cusseta/Opelika AL
    2010 Tacoma DC TRD Sport
    5100's set to 1.75" Wheelers 3 leaf progressive AAL & 5100's for the rear Konig Countersteer Offroads K&N Drop in WeatherTech's Bed Mat Blacked out Badges Rear leaf TSB
    Sounds like you need a little more leverage to undo the bolt. Just place a hollow pipe over the end of the ratchet. That will allow for more leverage and open sesame. Be careful not to strip the bolt though! I like to use a boxed end wrench in these situations rather than a ratchet. Hope this helps.
    X2 on the short socket if you don't have a wrench.
  5. Feb 24, 2011 at 2:11 PM
    adrianm2627
    California
    05 PreRunner V6 SR5
    Thanks all, for all the positive input.
    Much appreciated!
  6. Feb 24, 2011 at 2:23 PM
    judd94
    judd94 Well-Known Member
    Ponchatoula, LA
    17 4Runner TRD Off Road Premium
    Mods in Progress
    whatever you do make sure you don't drain the transmission. yes it has happened numerous times. somebody on here made a thread with pics to help. look under Mods at the top and theres a DIY Oil Change thread with pics for help
    if you think your plug is stripped or gonna get damaged to get it off maybe you should consider goin to the dealer and buying a new plug before you get started. remember once you get started your stranded til it has fresh oil
  7. Feb 24, 2011 at 2:57 PM
    scottri
    scottri Well-Known Member
    Scott
    Tigard Oregon
    '10 Sport DC TRD Sport PreRunner
    Cover King Seat Covers, WeatherTech Liners, PopNLock, storage bin locks, N-Fab Step bars, and G4 Elite Tonneau cover.
    Cheater bar (hollow pipe) and watch your knuckles! I've busted a few open over the years when the ratched exploded.
  8. Feb 24, 2011 at 4:18 PM
    TacoSport
    TacoSport opinions are like assholes; everyones got one.
    NE
    2011 TRD SSM Sport DCSB w/Tow
    before you take the bolt off I recommend going to Autozone and picking up a new bolt and gasket.
  9. Feb 24, 2011 at 4:20 PM
    adrianm2627
    California
    05 PreRunner V6 SR5
    Ok. The plug came off smoothly...just needed a new ratchet with power.
    Now to take off the old filter. Whatever they used...it's on there pretty tight.
    What do you guy's use?
  10. Feb 24, 2011 at 4:43 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    they have sockets that go over the filter
    find those to be the best
  11. Feb 24, 2011 at 4:48 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    I use one of these. Your 3/8 ratchet fits in the end and it grabs any size filter. Just google "oil filter claw".
  12. Feb 24, 2011 at 5:11 PM
    scottri
    Scott
    Tigard Oregon
    Pound a long screw driver straight through both sides and grab each end and twist. Works every time. ;)
  13. Feb 24, 2011 at 5:29 PM
    TacoSport
    NE
    I use the paw aka my right hand :)
  14. Feb 24, 2011 at 5:36 PM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    what ever you do, make sure you don't strip it!!
  15. Feb 24, 2011 at 5:40 PM
    hetkind
    Howard
    Johnson City
    Channel lock makes a dandy pair of oil filter pliers:)
  16. Feb 24, 2011 at 5:42 PM
    JKD
    JKD Well-Known Member
    If your socket is crap, go buy a less crappy socket set.
    The basic Craftsman socket set at Sears works just fine.
  17. Feb 24, 2011 at 7:20 PM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4R MGM TRDOR Premium Daddy Wagon
    Craftsman tools for life! Leave the crappy stuff alone, this is one area where you definitely get what you pay for.
  18. Feb 24, 2011 at 9:29 PM
    island808
    island808 Me l've got brains.
    Jedediah
    hawaii
    '10 6speed 4x4 access cab
    No balls, Just grab the filter with 2 hands and take it off.
    If you can't. Take off your belt, wrap it around and pry with that. If you still can't get it off, call your wife to do it for you.. BAM.
  19. Feb 24, 2011 at 9:32 PM
    island808
    Jedediah
    hawaii
    I've been very happy with my stanley kits seem like the same tools as craftsman (i have a mix ) and Craftsman is way expensive, and I saw a show that said the only thing craftsman still made was ratchets. Everything else is re-branding. Of course you get the warranty. But I like to lose my tools. They don't replace that.
    I've found that craftsman and stanley come out with the same new tools at about the same time, all the time. Might be a slightly different process. But usually if you're breaking sockets, you're abusing them, unless they're really cheap. "chrome vanadium" brand stuff.
  20. Feb 24, 2011 at 10:24 PM
    fvtalon
    fvtalon Well-Known Member
    Southern BC
    07 DC TRD/Yamaha
    285/65/18 BFG ATs on MKWs Leer Cap
    In my toolbox I have a chunk of steel pipe about 16" long with cloth hockey stick tape on it. It fits over my ratchets when I have a real stubborn bolt for some extra leverage. It sounds like your biggest problem though is you need some decent tools. If you're going to do your own work do yourself a favor and buy some decent tools. Craftsman or Stanley, like mentioned are going to work. Stripping or breaking bolts or slipping off a bolt and busting up your hand just isn't worth it, decent tools aren't that expensive and you'll easily save the cost doing your own work. If you're using wrenches on a tight bolt you can hook two wrenches together for extra leverage, see pic:
    Just be sure to keep the wrenches lined up or they will slip.
    To get filters off there's special filter wrenches. I never need them on my own vehicles because I've never had an issue when the filter was put on properly. Same with the drain bolt. It just needs to not fall out, it doesn't need to be gorilla tight.
