Changing oil at 1k
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 2023tacomer, Aug 11, 2023.
  1. Aug 11, 2023 at 6:54 PM
    2023tacomer
    2023tacomer [OP] Well-Known Member
    I've decided I will change the oil at 1k, then again every 5k miles. With that said, I have a lot of oil. I mean a lot. Anyone here using the shell gas and truck 0w20 with good results in the 6 cylinder? I have over 30 gallons.
    Thanks
  2. Aug 11, 2023 at 6:57 PM
    Just_A_Guy
    Just_A_Guy Rain is a good thing
    On the hunt
    A truck
    There are thousands of oil threads on this site.
    TLDR: Use an SAE certified oil at the correct weight, keep your receipts for the oil, should be fine.
  3. Aug 11, 2023 at 6:57 PM
    Cushmaat
    Cushmaat Well-known wiseass.
    SE AZ
    2022 TRD OR 4x4 DCLB MGM
    I also walk to school and bring a lunch.
    TGIF!
  4. Aug 11, 2023 at 6:57 PM
    Just_A_Guy
    On the hunt
    A truck
    AT THE SAME TIME?!
    clg, dleithaus, Delta09 and 2 others like this.
  5. Aug 11, 2023 at 6:59 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
  6. Aug 11, 2023 at 7:28 PM
    Silverlogic
    Silverlogic Well-Known Member
    Tyler
    San Diego, California
    2018 Silver DCSB TRDOR
    How did you come across 30 gallons of oil?
    TacoSR523, D.A.S. Taco and HondaGM like this.
  7. Aug 11, 2023 at 7:34 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Shop lifting…
    jpstacoma, rhdsjhn, TacoSR523 and 7 others like this.
  8. Aug 11, 2023 at 7:40 PM
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    Not Karen
    The wild west
    2016 SR5 DCSB
    Aesthetically Challenged
    he owns a large chunk of land in texas.
    I wonder if this thread will exceed 10 pages by the end of Monday?
    TacoSR523, Chew, Squirt and 3 others like this.
  9. Aug 11, 2023 at 7:51 PM
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
  10. Aug 11, 2023 at 8:17 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    That'll be roughly 240 pounds including the drum. I want to know what brand of jacket can pocket that one.
  11. Aug 11, 2023 at 8:34 PM
    AmateurTaco1313
    AmateurTaco1313 Next truck will be a Hilux
    ROK
    2018 TRD Sport 4WD DCSB
    Enough for now
    curious as to why to keep the receipts? Legitimately asking
    clownkillerloaf and TacoSR523 like this.
  12. Aug 11, 2023 at 9:10 PM
    Kolohe07
    Kolohe07 Well-Known Member
    David
    Haiku , Maui, Hi
    2022 Access cab Sport 4x4 Celestial Silver
    I did my first change at 3k and the oil was filthy.
    Everyone will give you their opinion.......
    Go for it if you have the oil.
    Motivex oil change tools help a lot. OEM filter.
    Cut down a 5 gal bucket to fit under your truck , because the 20 w is super runny and will splash all over a shallow tray.
    AaronGif, gsubioguy and TacoSR523 like this.
  13. Aug 11, 2023 at 9:22 PM
    2023tacomer
    I am a member of bobistheoilguy. Deals are listed. I paid like 7 dollars per 2.5 gallons. I also scores idemitsu 0w20, like 15 gallons, at 1.95 a gallon lol. Oh, and 10 gallons of Castrol 0w20, free. I also have about 20 gallons of shell rotella 15w40 syn, but that's not for the tacomer.
    TacoSR523, RustyGreen and D.A.S. Taco like this.
  14. Aug 11, 2023 at 9:32 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    To provide evidence of oil changes when making a warranty claim.
  15. Aug 11, 2023 at 9:47 PM
    TacoTuesday1
    FL
    Just checked BITOG and don't see anything. If you know of any deals please PM me.
    I think 1000 oil change is a good idea. New engines during breakin have more debris circulating.
    Especially if you got it cheap or free. That's generally the limitation people set on OCI's; the cost of oil.
    "I'm gonna ruin my $5k engine with 10k mi OCI's because I don't wanna buy a $12 5gal jug of oil, anyway I'll have the $50 kobe wagyu combo"
    I have a 2nd gen that calls for 5w30 that I don't think is picky.
    I've ran 0w20, 0w30, 5w30, 0w40, 5w40, or mixes of it.
    There have been times when I took half a jug of 0w20, poured in half a jug of 5w40, a can of BG MOA, and shook it.
    The oil pump and engine also mix it.
    One thing I'd be curious to try/see if it works is Shell Rotella T6 5w40. It's a good oil, higher in cleaning detergents due to being designed for diesel.
    And decently priced. Probably better than regular M1.
    people run it in motorcycles and gas cars all the time, to include old Audi's.
    D.A.S. Taco likes this.
  16. Aug 12, 2023 at 6:02 AM
    WNYBill
    WNYBill Active Member
    Bill
    Tacoma SR
    Are you all using full synthetic?
  17. Aug 12, 2023 at 6:11 AM
    tiap
    tiap Active Member
    On a new engine I've always changed the oil and filter at less than 500 miles
    There will be more metal floating around in the oil from initial surface wear in than there ever will.
    Never hurts to use magnetic drain plugs as well. There will always be metal fuzz accumulate there.
    Every little bit helps.
    22 Sport likes this.
  18. Aug 12, 2023 at 6:15 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    I don't think you can get 0W-20 in anything other than full synthetic.
    David2431 and SmoothTRD like this.
  19. Aug 12, 2023 at 6:20 AM
    musicisevil
    Alaska
    2019 TRD Sport
    Not with that attitude! You have to do a custom blend. My taco likes avocado oil and a touch of chili oil to keep things spicy
  20. Aug 12, 2023 at 6:45 AM
    2023tacomer
    I mentioned bobistheoilguy and the deals. Those deals are not going on now, I hoarded when going on. Sorry
