Changing oil filter housing from hard plastic to metal
Discussion in '3rd Gen. Tacomas (2016-2023)' started by patos tacoma, Jun 4, 2023.
  1. Mar 5, 2024 at 5:04 AM
    #141
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    IIRC that's internal to the engine with cartridge filter setups.
  2. Mar 5, 2024 at 5:07 AM
    #142
    TS4x4
    TS4x4 Well-Known Member
    2018 TRD Offroad
    After dealing with a stuck plastic filter cap, breaking my removal tool, and needing to use a heat gun and my backup metal removal tool, I will definitely be switching to the aluminum housing on my next oil change. It turned what should have been a 30 minute process into a 2 hour ordeal. The whole time I was sweating trying not to break the actual oil pan. Not fun.
    For reference I do my own oil changes and aways torqued everything to the correct spec so there's no reason it should have gotten stuck. The truck has 95k miles on it so they only thing that I can think of is the plastic is somehow warping on a small scale.
  3. Mar 5, 2024 at 5:16 AM
    #143
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    for some reason, the polymer seems to expand when it is warm or hot. Not ideal, but drain the oil while warm/hot. Wait an hour and remove polymer the filter cap. When relatively cold, if removes rather easily.
  4. Mar 5, 2024 at 7:00 AM
    #144
    tollster64
    tollster64 Well-Known Member
    Pennsyltucky
    2019 TRD DCSB
    I’m changing mine out from plastic to metal. Even with the proper torque specs and lubing the gasket, it’s a bitch to unscrew. I will say when I change my oil, the engine is still warm after draining, and I believe the nylon reinforced plastic has different expansion and compression rates than aluminum, thereby creating additional drag on the threads when warm.
    TS4x4 and faawrenchbndr like this.
  5. Mar 5, 2024 at 7:46 AM
    #145
    TS4x4
    2018 TRD Offroad
    It was ambient cold ~ 50F. It had sat overnight before I went to change it.
  6. Mar 5, 2024 at 7:52 AM
    #146
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    It’s crazy……..the alloy cap is much better
    TacoTime55 likes this.
  7. Mar 5, 2024 at 9:21 AM
    #147
    TacoTime55
    TacoTime55 TT58
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    This is getting very particular...which is ok, just long-drawn out discussion....which I'm not complaining about...lol!
    After inspecting both housing units...and I've posted photos of the aluminum...they are just about identical...if not identical.
    The center piece tubing was the only slight difference. (It can be removed with a push down & twist if you want to replace it with the hardened plastic housing unit's center piece)
    I was skeptical at first but then on the next oil change, and with the correct filter...I went ahead and R2'd it!
    While I was at it, I installed the Fumoto valve...no leaks with either new replacement parts!
    NOTE: R2=Remove & Replaced
  8. Mar 5, 2024 at 10:07 AM
    #148
    TS4x4
    2018 TRD Offroad
    I agree that they're both visually the same with the difference in material construction. But that's also the point here. The metal unit should last longer and be less prone to degradation over time. The plastic unit correctly torqued can still end up seizing as I've experienced.
    TacoTime55[QUOTED] likes this.
  9. Mar 5, 2024 at 10:34 AM
    #149
    Irons
    Irons Outlaw Prospector
    NW Michigan USA
    '22 TRD Sport AC MT Army Green
    TRD lift, Exhaust & CAI
    I wonder if the plastic one is lighter.
  10. Mar 5, 2024 at 11:17 AM
    #150
    TS4x4
    2018 TRD Offroad
    If it is, it can't be more than a couple of grams. Hardly qualifies as weight reduction.
    Irons[QUOTED], TacoTime55 and Jakerou like this.
  11. Mar 5, 2024 at 12:59 PM
    #151
    TacoTime55
    TacoTime55 TT58
    Ed
    Delaware
    If that!
    I can't even remember noticing a significant weight difference when I held them both.
    Of course...one had oil residue while the other was (almost) as clean as a whistle before I installed it.
    TS4x4[QUOTED] and faawrenchbndr like this.
