Changing oil filter without making a mess
Discussion in '2nd Gen. Tacomas (2005-2015)' started by retired_librarian, Jan 16, 2023.
  1. Jan 18, 2023 at 12:00 PM
    ACEkraut
    ACEkraut Well-Known Member
    Aaron
    Durham, Maine
    2014 DCSB TRD Off Road
    This is what I did. Only thing I did different is to use clear tubing.
    OffroadToy[QUOTED] likes this.
  2. Jan 18, 2023 at 5:52 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Some of you are missing the fact that the OP has a 4 cyl, not a V6. Oil filter on 4 cyl is removed from below.
    po35042 likes this.
  3. Jan 31, 2023 at 7:23 AM
    retired_librarian
    retired_librarian [OP] Member
    Theo
    2006 Toyota Tacoma
    Any suggestions for accessing the oil filter on a 2006 Toyota Tacoma? Has anyone tried accessing the oil filter from behind the passenger tire? Like most of you, doing this work is not so much about saving a few bucks but rather maintaining some independence. Warm regards, Theo
  4. Jan 31, 2023 at 9:36 AM
    BigCountry762x39
    BigCountry762x39 Well-Known Member
    TL
    PNW, Oregon!
    2009 Tacoma, with the cool white paint peel
    Arb Deluxe bull bar Front Bumper Ironman4x4 12k winch synth line AFE Intake OME 2.75in Dakar Leaf springs (R) Fox 2.0 bypass shocks (R) Bilstein 6112 (F) 33's on KMC wheels off road lighting comfort mods Redrock HD roof rack Retevis rt95 Radio Slotted Rotors and HD pads
    had a friend with an FJ when i was a tech, use to hate having to always remove his skid plate after an oil change because it always poured into there and would drip on his driveway. threw a piece of smaller fuel line or something i had tucked it down the side of the engine bay an said blast some brake cleaner down the hole and should be clear after each change.
  5. Jan 31, 2023 at 11:02 AM
    PhxRising85
    PhxRising85 AMSOIL Dealer
    Logan
    Surprise, AZ
    2008 SR5 2WD LB Tacoma
    Fox 2.0 Suspension, Diode Dynamics Driving Lights, AMSOIL
    Dang, I feed dumb for not seeing the drain connection on the Oil Filter for the V6, definitely going to install a clear tube and letting it drain down that.
    OffroadToy likes this.
  6. Jan 31, 2023 at 11:49 AM
    tacoman45
    tacoman45 Well-Known Member
    Orygun
    2014 TRD OR DCSB - MGM
    Pretty sure it's 3/8" or 5/16" tubing for the drain nipple on the V6 Oil Filter Cup. Friendly FYI
    PhxRising85[QUOTED] likes this.
  7. Feb 1, 2023 at 7:08 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    i used 5/16" ID fuel line
    tacoman45[QUOTED] likes this.
