changing oil first time, any words of wisdom?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by stevetaco, May 29, 2012.
  1. May 29, 2012 at 8:58 AM
    stevetaco
    stevetaco [OP] Active Member
    steve
    CA/OR border
    Plain Jane Silver Streak
    First time for me... been done at dealer until now.
    Truck has 40k on it.
    Plan on using synthetic oil.
    Whats the capacity?
    Any suggestions on what filter to use? Must be easy to find.
    THANKS>>>>:)
  2. May 29, 2012 at 9:05 AM
    Large
    Large Red
    4.0 uses a little over 5 qts iirc so you need to buy 6, like he said use an OEM filter.
  3. May 29, 2012 at 9:07 AM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    03 F250 CCSB
    Gibson stainless headers, custom free-flow Y-pipe, Magnaflow muffler, 285/75R16 KBro2's
    Don't pull the transmission drain plug by mistake.
    EDIT: Just noticed the OP's truck looks like a base model which likely has the 2.7L. I know nothing about those engines, so look in your manual towards the back. There will be a section that talks about "Specifications and Capacities". As others have said, buy a Toyota filter. As for the oil, I think the majority of folks on this site run Mobil 1.
  4. May 29, 2012 at 9:07 AM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    Make sure you are draining the oil, and not the transmission fluid.... Oil plug is the one towards the front.
  5. May 29, 2012 at 9:58 AM
    stevetaco
    steve
    CA/OR border
    thanks... I am really new at this.
    The engine is 4 cylinder, 5 speed.
    I got the oil drained. So guess i got right plug.
    Then tried to remove filter. No can do.. with my filter wrench, since filter is kinda recessed with a bunch of stuff around it.
    Guess I have to buy a filter "socket".
    Anybody got a good recommendation on what to buy...
    like brand, product #, etc.
    I remember I bought one years ago and it slipped really bad.
    I have Auto Zone, Walmart, Napa, ORiely's near me.
    thanks again..
  6. May 29, 2012 at 1:12 PM
    jester156
    jester156 Well-Known Member
    Cumberland, RI
    08 V6 4x4 DC TRD, 6spd
    TRD Supercharger, TRD CAI, Sirius, Rear TSB, Front 5100 with Eibach coils, 1.5" AAL, URD short throw, fog light mod, weather tech liners,
    stab it with a screw driver, then don't install your new home with gorilla force.
  7. May 29, 2012 at 1:21 PM
    theredofshaw
    theredofshaw Well-Known Member
    Reno/Sparks, NV
    2016 Honda Civic (guess that means I can be a MOD now)
    (totaled) 2011 Tacoma DC
  8. May 30, 2012 at 6:28 AM
    stevetaco
    steve
    CA/OR border
    thanks everyone and thanks for the link with all the info.
    think I got it figured out....
    I bought the truck new, and had all the oil changes done at the DEALER up until now.
    Anyway.... when they changed the oil, they did not use a Toyota Filter.
    They USED SOME CHEAP ASS FILTER instead !!!!!!
    What a bunch of cheap bast**ds !!!!!
  9. May 30, 2012 at 8:07 AM
    Maticuno
    03 F250 CCSB
    Cheap bastards suck. More reason to always do your own filter.
