Changing Oil on a 2.4L Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by herdavid1991, May 6, 2024.
  1. May 6, 2024 at 3:12 AM
    herdavid1991
    herdavid1991 [OP] Member
    David
    2003 Toyota Tacoma, 5 Lug, 2.4L, 2 wheel drive
    so the service manual said 5.8qt, is it okay just to put 6qt?
  2. May 6, 2024 at 3:23 AM
    Pbfender15
    Pbfender15 Well-Known Member
    multiple 1st gens
    Put in 5.5 and measure on the dipstick. Add more as needed. You don't want to overfill.
  3. May 6, 2024 at 5:40 PM
    herdavid1991
    David
    gotchu. thanks.
  4. May 6, 2024 at 5:57 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    No......if I change without the filter....its 4 and 1/3 qts.....
    So with filter just under 5qts
    I use 1/4 qt of the lucas synthetic additive.....so I have to eagle eye it every time...
    The number they're giving you is for 3rz.......you know the one with the bigger taller oil pan that has to fit around the 4X4 crossmember/steer rack.....
    Same thing.....jack asses tell you the auto trannys use 2 qts.....
    that's only 7 and 1/2 qts short of reality....
