changing oil weights
Discussion in '1st Gen. Tacomas (1995-2004)' started by ERIC, May 4, 2011.
  1. May 4, 2011 at 1:33 PM
    ERIC
    ERIC [OP] Well-Known Member
    Eric
    Orange County, CA
    2002 Impulse Red TRD PreRunner SOLD
    Pioneer double din navi head unit and four 5x7 alpine speakers, westin light bar, procomp lights, head and tail lights, black billet grille, billet antienna, gibson headers and cat back exhaust, afe cold air, uni chip programmer, Bilstein 5100's, Pro comp wheels and tires, tint, blacked out emblems, innu roof rack, yakima basket, foglight mod...
    Do any of you guys change the oil weight after 100000 miles? Ill be there my next oil change and Im thinking about using 10w30 instead of 5w30. would the added thickness be bad for the oil pump?
  2. May 4, 2011 at 2:20 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    The only difference between oil weights is the thickness of the oil. Sometimes i run 10w in the summer and 5w in the winter. Oil likes to get thicker in the cold so 5w runs easier in the winter.
  3. May 4, 2011 at 2:30 PM
    ontarioyota
    ontarioyota Well-Known Member
    SW Ontario, Canada
    01 reg cab 4x4
    Blacked out badges-rims OME lift with 881's & dakar pacs with D6XL AAL (removed), summer tires=BFG 31x10.5x15 on 93 4runner rims,winter= 265 75 16 DURATRACS on stock steelies,Flowmaster exhaust, deck plate mod, ARB front bumper
    Stick with the 5w30=less engine wear at start up
  4. May 4, 2011 at 2:35 PM
    ERIC
    Eric
    Orange County, CA
    yea thats what i was thinking. Its gettin hot out here so a thicker oil might help.
  5. May 4, 2011 at 3:40 PM
    Cvd2312
    Cvd2312 Well-Known Member
    Cory
    Oregon
    97 Tacoma 3.4L
    Bilstein 5100's all the way around, 2" shackles in rear, front diff drop, 32x11.50.15 BFG A/T, 15x8 Ultra 164 Wheels
    You should keep running 5-30.
  6. May 4, 2011 at 3:47 PM
    Enigmaaron
    Enigmaaron All your soul are belong to us
    PA
    1st gen superiority
    X2
    Toyota probably tested the truck in harsher climates than you have in CA. They decided on 5W-30, I would trust them.
  7. May 4, 2011 at 5:56 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Use synthetic. It's more stable over a wider range of temps. Stick with what Toyota recommends for the temp ranges you expect to drive.
  8. May 4, 2011 at 6:10 PM
    Norton
    Norton Senior Member
    Monument, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C, OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; aFe POWER Magnum FLOW Pro DRY S Air Filter; NSB-AGM27F Battery w/Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Cooper Discoverer A/T3s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; MetalMiller TRD Skid; jsi's Locker Anytime & ramonortiz55's Always on Power Outlet Relay Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades (RallyLights Harnesses, Osram 85/80W H4 & Flösser 90W H11 Bulbs); mattgecko's Underhood Lighting; ND4's Fog Light Anytime Mod; Interior & Reverse LEDs; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; 4Runner 4X4 & FJ Fog Light Switches; Husky Floor Liners; UltraGauge EM; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Toyota Bed Extender; Pop & Lock Power Tailgate Lock; ARE Z-Series Cap, SolarGard Tint; BlendMounted BEL Vector 995; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    x3.
    x2.
  9. May 4, 2011 at 9:07 PM
    stucksucksnayota
    stucksucksnayota Well-Known Member
    Barry
    Fort Smith, Arkansas
    14 Taco 4x4 TRD Sport DCSB
    OEM roof rack, Shorty antenna (eBay), soft tonneau cover, K&N drop in air filter, bed mat, interior LED lights, 5100's, MT tires to come soon!!!
    Stick to what your engine was designed and engineered to run in it!
    Theres a reason they spend millions of dollars on testing and engineering.
  10. May 5, 2011 at 8:17 AM
    Quid
    Quid Member
    Tom
    Ventura County, CA
    K&N FIPK2 Intake Audiovox Cruise Control
    198000 miles on 5w30. No oil consumption. I'm sticking with the stock weight with results like that!
  11. May 6, 2011 at 3:58 AM
    sourdough44
    sourdough44 Member
    WI
    Sold my 2000 Tacoma
    I see your in CA. I certainly would envision no problems if you did go with a minor change like 10w-30. When was the last time you ever had a start below 32 degrees? I know you have the mountains nearby with snow & all. Here in the cold I often go with synthetic in the Winter & back to conventional in the Summer.
    I know were not suppose to put thought into all this, just blindly follow the book to handle the 'averages'. That said there is a big difference between cold starting at 10 or more below zero & summer averages of 65+.
  12. May 6, 2011 at 4:44 AM
    travelingman
    travelingman What would Scooby do?
    Brian
    Ohio
    07lb4x4DC
    ticking eng.mo,ventvisors,locking tailgate,wheelmasters ss spare tire inflation line,weathertech mats
    No advantage.you're mileage will probably drop.No reason for it.Stick with 5-30.
  13. May 6, 2011 at 5:44 AM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    If you change your oil at the recommended intervals, 5W30 has the same thickness as 10W30 once the oil reaches operating temperature. 5W30 is thinner when the engine is cold, so it flows easier at startup. There's basically no reason to go with 10W30 if 5W30 is available...
  14. May 6, 2011 at 6:38 AM
    brelandt
    brelandt Well-Known Member
    Terry
    Dublin, CA
    04 Prerunner reg cab SR5
    3" lift front and back
    As am automotive repair student I can tell you what we learned. The reason for the manufacture choosing the weight has everything to do on how the oil performed in certain areas of the engine due to the clearance of that engine. The oil supports all of the weight of the crank as it spins. It supports the camshafts as it spins. Both areas will fail if the wrong weight is used over a long period of time. Also the oil has to "hold" to the cylinder walls and a small amount gets burned in the process. Wrong weight in this area will cause piston slap and ring wear or even failing emissions.
    so stick to the weight listed.
