Changing out a Wheel bearing! (How to)
Discussion in 'Wheels & Tires' started by battleyota, Jan 26, 2013.
  1. Jan 26, 2013 at 5:43 PM
    battleyota
    battleyota [OP] Well-Known Member
    David
    Oahu, HI
    Beast of Destruction
    OME suspension, All-Pro UCA, rear locker, 4.56 gears front and rear diffs, rear dif locker, 32x11.5 BF Goodrich Mud Terrians KM2, 15x8 Mickey Thompson classic lock, ARB bumper, K&N Air filter. Safari Snorkel.
    Ok, I am putting this thread together cause I've looked everywhere on how to change out a wheel bearing. So I decided to put one together and after hours and days of learning how to do so and running into problems. I am finally done with the finish product. (I used my 1995 Tacoma to change out the bearings, but I am sure that this could be a guidance for the 2nd Gen's.)
    So after taking off the tire I started on the brakes.
    I tied up the breakpads to keep stress off the line and keep it out of the way
    I have Manual locking hubs, make sure its in the free position. If you don't have manual locking just make sure you're out of 4wheel drive, and there will be a cap after you take off the cover.
    Next comes this, The Red arrows are where you may have to bang the hell out of those screws with a brass hammer or a brass pin. This was the second hardest thing to do. once you bang it loose the cone shape washers will pop out.(The next pic I will show)
    The Yellow arrow is where you need to unscrew the bolt out before you can take it down further.
    Now the next part after taking off the silver star piece (I am horrible with technical names)
    you'll come to exposing the axle spindle
    This was the hardest for me. That retaining pin was a bitch.
    If you haven't taken of the disc brakes yet then go ahead and do so.
    Now the next step is to take of the whole knuckle. You'll need to unscrew 4 screws on the bottom where it connects to the lower control arms. Then disconnect the upper control arm.
    Now you'll have the Whole knuckle out
    After much searching for a special socket, I found one From MatCo Tools. This socket fits in these holes
    Also The Yellow Outline is where a seal was, You'll have to get one of those for the front and back of the wheel bearings.
    I put the knuckle in my wheel to brace it better when unscrewed it.
    Now the final step is to Press out the old bearings and put in the new ones.
    I had to go to a machine shop and get it pressed out and the new ones pressed in.
    Then just backtrack everything and put it back together. Hope this helps out
    Note: use a torque wrench to tighten in the wheel bearing socket nut at 203 ft lbs.
    I re-packed the grease in the bearings, Only was able to get one side of the bearings off to re-grease it.
    Be easy on the bolts and screws, I sheared off one.
    Allex95, yayayayayaya and boostedka like this.
  2. Jan 26, 2013 at 5:53 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Nice write up! +1
    This should be added to the "DIY" thread.
    Question,
    are the steps similar for non-lockable hubs?
    and how much was the tool?
  3. Jan 26, 2013 at 5:58 PM
    battleyota
    David
    Oahu, HI
    Ya didn't cross my mind, thought having it in the wheels and tires thread where a little bit more specific.
    The non-lockable hubs should be the same.
  4. Jan 26, 2013 at 6:04 PM
    vbibi
    vbibi Well-Known Member
    san fransisco bay area
    2009 4door long bed
    Nice, Can you tell us the part # for the tool so we can buy it in advance?
    thanks
  5. Jan 26, 2013 at 6:11 PM
    battleyota
    David
    Oahu, HI
  6. Jan 27, 2013 at 8:25 AM
    SPOTSONTROUT
    SPOTSONTROUT Well-Known Member
    ROB
    SOUTHERN ONTARIO CANADA
    03 TRD Stolen
    OME 882,DAKAR LEAF PAC WITH ADDA LEAF,285 TOYO OPEN COUNTRY MT,RACELINE RENAGADES,DECK PLATE MOD, MANUAL HUB CONVERSION
    Hey great write up. Your right about those cone washers.
  7. Jan 27, 2013 at 8:45 AM
    myfirst06taco
    myfirst06taco Well-Known Member
    Clarke county ,VA
    06 SR5 4X4
    5100's eibach coils , Allpro leaf pack , roll up tonneau cover with led bed lights, hids, homertaco grill
    Not much guidance for the 2nd gen , just did mine last month on my 06 . Great write up for all the 1st gens. Btw 2nd gen was much easier than this looks (no special tools required).
  8. Jan 27, 2013 at 8:11 PM
    battleyota
    David
    Oahu, HI
    Thanks, This was a bitch cause I had over 200k on my truck. Alot of bolts and screws were stuck. :eek:
  9. Jan 27, 2013 at 8:22 PM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    1988 Pickup 22R 5sp 2wd
    Weber 32/36, RV Cam, LCE exhaust headers, Desmogged
    excellent write-up, man! this is a huge reason i love this site...
  10. Jan 27, 2013 at 8:29 PM
    battleyota
    David
    Oahu, HI
    Thanks. I'd figure, I would help out by writing this up.
  11. Jan 27, 2013 at 8:52 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Nice work.
  12. Jan 27, 2013 at 9:02 PM
    Tylerm5000
    Tylerm5000 Well-Known Member
    Tyler
    Oregon
    1995.5 2.7l reg cab 4x4 5-speed red pearl
    Alcan stock height 4-leaf springs, greaseable main eye bolts, OME greaseable shackles, all energy suspension bushings, 2-row extra deep radiator, KYB gas-a-just shocks. ALL LED exterior and interior lighting including custom tail lights and blinkers.
    Been there! That tool was freaking expensive. 70 dollars. Did you torque it to spec? Luckily my neighbor/mechanic had a really accurate torque wrench that went that high!
  13. Jan 28, 2013 at 9:15 PM
    battleyota
    David
    Oahu, HI
    ya, I was working in a Auto Shop and they had all the tools I needed.
  14. Oct 23, 2013 at 7:30 AM
    thedooties
    thedooties Member
    Elgin, Texas
    2.7L Tacoma 4WD
    I wish this was posted about three months earlier. It would have made my week a lot easier. Great write up.
    As for the 4-pin axle nut, I also set my hub back in the rim and used a pipe wrench to take it off and put back on on. I didn't have a torque wrench that could torque to the specs but just cranked it down as snug as possible and then backed it off a quarter turn. So far, it has worked out. I will be adding a 4-pin socket to my toolbox.
  15. Feb 25, 2014 at 7:45 AM
    Yoda the Taco
    Yoda the Taco Well-Known Member
    Chase
    Kingsport
    Majestic White Stallion
    00 front end swap 3 inch spacer/block 01 dash swap Flux capacitor 04 center console tach cluster swap avatar-10 hyperdrive 02 door panels powerlocks/keyless entry electric fan swap 4runner seats
  16. Apr 7, 2014 at 10:18 AM
    jbarclay11
    jbarclay11 New Member
    SF Bay Area
    2000 Tacoma 4x4
    none
    Does it make a difference which side of the bearing is pressed into the steering knuckle of a 1st gen 4x4 without freewheel hubs?
  17. Apr 7, 2014 at 10:26 AM
    BamaToy1997
    Bill
    Navarre, FL
    The wheel bearings on the 1st gen only go in one way. Regardless of the type of hubs.
  18. Apr 8, 2014 at 1:03 PM
    jbarclay11
    SF Bay Area
    2000 Tacoma 4x4
    none
    I wasn't specific enough. The new OEM bearings for a Tacoma with ADD seal is metal on one side, and plastic on the other. What I meant to say is what side of the bearing is towards the engine. I suspect the metal side.
    Thanks for the earlier reply.
  19. Apr 8, 2014 at 7:10 PM
    BamaToy1997
    Bill
    Navarre, FL
    I hadn't really noticed that myself. I haven't installed one incorrectly so far, and never recall noticing that one side was different than the other. Maybe one brand is different than the other? Not sure.
  20. Aug 24, 2016 at 4:50 PM
    KillaBoDilla
    KillaBoDilla Member
    04 PreRunner DBLcab
    Is any difference between the 2 wheel drive PreRunners vs this 4 wheel drive write up? I cannot find any information or write-ups on a 1st gen PreRunner 2wd front bearing replacement.
