Changing out AC condenser
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Lommadogg, May 28, 2023.
  1. May 28, 2023 at 10:28 AM
    Lommadogg
    Lommadogg [OP] Member
    2013 Tacoma Double Cab
    1-10, how hard is it to change out a leaking AC condenser? I am a bit handy, changing oil, swapping our bad radiator hoses., plugs, etc. Should I give it a go?
  2. May 28, 2023 at 10:44 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Not hard but you need proper equipment to evacuate, vacuum, and recharge the A/C system.
    6 gearT444E likes this.
  3. May 28, 2023 at 11:08 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    It’s about a 3 hour job but as stated you need a proper tools for it. I’d recommend new seal kit too for the orings
  4. May 28, 2023 at 11:13 AM
    Rob MacRuger
    Rob MacRuger Well-Known Member
    2006 4X4 SR5 4.0
    I did mine a few years ago. It was not difficult. Get some new gaskets for the AC lines.
    I bought the Napa brand and had to fabricate the upper mounting. I should have bought Denso.
    I had remove the grill and the radiator bolts.
  5. May 28, 2023 at 11:40 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Easy. 4 out of 10
  6. May 28, 2023 at 4:14 PM
    Lommadogg
    Thanks everybody
  7. May 28, 2023 at 4:47 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Like others have said, it's not difficult. We did a new compressor and condenser in my son's car a few years back. I bought a Harbor Freight vacuum pump to pump down the system. I've only used it that one time but for the $ you save doing it yourself, you'll more than pay for the pump. Maybe someone has a pump you can borrow. You need to pump the system down once you get it all sealed up, before you charge it.
  8. May 28, 2023 at 5:07 PM
    Madd Matt
    Madd Matt Well-Known Member
    Between the Brandywines S.E. Penna.
    2015 Blue Tacoma TRD Sport 4.0 6 speed manual
    You can borrow the pump and gauges from Auto Zone.
