Changing out front spacers for OMEs or 5100s, more info needed!
Discussion in 'Suspension' started by eltaco, Sep 14, 2009.
  1. Sep 14, 2009 at 7:15 PM
    eltaco
    eltaco [OP] Well-Known Member
    Littleton, CO
    '07 4x4 DC Offroad
    So I think I've read enough posts to make my head spin, any additional information that you all can provide would be quite useful!
    I've had 2.5" spacers in the front of my truck for about 30k miles, and I'm finally looking at puting in some new UCAs to correct my alignment issues. It doesn't seem that the alignment is terribly off, but I finally have the means to fix it the right way and see how the truck is supposed to drive.
    I'm looking at a couple of different options, not sure which way to turn. I was considering grabbing the 5100s and some OME 885 coils, but I'm curious if it would be a big improvement to go with the OME N140s shocks with the 885 coils. I also saw that some went with Eibach coils, not sure which way to go... any input? I know downsouth has a good price on the 5100s. Who has good pricing on the OME or Eibach parts?
    I'm not a hardcore offroader; I might hit the moutain roads 15% of my overall driving. That being said, I am pretty stoked on the Camburg Ball-Joint UCAs for $379, since I don't feel the need to have more articulation. Basically, since I'm going to have the front end pulled apart, I figure I might as well kill two birds with one stone. Are there any comparable options that I'm unaware of?
  2. Sep 14, 2009 at 7:18 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    With the OME shocks, you can add a shim to account for the driver side lean. The 5100's can be adjusted via a small spacer on the top plate, or you can get the 5100's with the threaded collars. Personally, I think the OME shocks are a little bit softer than the 5100's. Not a good or bad thing, just an observation.
  3. Sep 14, 2009 at 7:21 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    x2. I had the OME shocks and coils and loved the ride. But I dont like the rear OME shocks. Too soft.
  4. Sep 14, 2009 at 7:21 PM
    eltaco
    Littleton, CO
    '07 4x4 DC Offroad
    It looks like the 5100/OME 885s will be about $130 less than the N140s/885s, unless I'm missing something somehwere.
    I have read that the 5100s/885s should give 2.5" of lift with the 5100s at the lowest position, is this correct? Will the 885s sag over time? I currently have the stock 16s, spidertrax spacers, and 285s, so I'd hate to see it sag and rub more...
  5. Sep 14, 2009 at 7:24 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    You can get the 1/4" top plates and they will give you the full 3"
    And if you do get the 5100's you leave them at 0" of lift with the 885's
  6. Sep 14, 2009 at 7:26 PM
    eltaco
    Littleton, CO
    '07 4x4 DC Offroad
    Any chance I'll have an issue with the 1/4" plates and the camburgs binding?
    Any info on where to get these parts at a decent price?
    Thanks for the help, fellas. This is going to be the first time I've messed with front suspension. I'd rather spend an hour or two learning here to save me lots of headache in the future.
  7. Sep 14, 2009 at 7:27 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    toyteclifts.com
  8. Sep 14, 2009 at 7:27 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Wheelers Off road. They are a vendor on here.
