changing out fuel filter?
Discussion in 'Performance and Tuning' started by .Trdtaco315., May 15, 2010.
  1. May 15, 2010 at 5:41 PM
    .Trdtaco315.
    .Trdtaco315. [OP] Well-Known Member
    Will
    Santa ana
    03 Trd SR5 Prerunner
    is it easy? just take it off and put new one on?
  2. May 15, 2010 at 5:55 PM
    carmellocafe
    carmellocafe Begin With The End In Mind.
    KEVIN
    N. California
    2014 TRD OR Access cab longbed
    Not on a 2nd gen. :confused:
  3. May 15, 2010 at 5:56 PM
    .Trdtaco315.
    Will
    Santa ana
    mines a 1st gen
  4. May 15, 2010 at 6:04 PM
    mrp192
    mrp192 REALLY!!
    Brent
    Cheney WA
    2017 Tacoma Dbl cab long bed.
    Hood Strusts, remote Start, truck came with Leveling kit and wheels.
    its not not at all if i remember right its right by the transfer case on the keelson side of the frame rails. you need to pull the fuel pump fuse or relay. when i did it i could find them. if you find it let me know!
    anyways after you pull the fuse/relay run your eng until it dies and then try it a few more times so you know all of the fuel is out of the lines.. then you just unblot the filter and bolt it back on..reinstall the fuse/relay and your done. should take less then 30mins.
  5. May 16, 2010 at 3:22 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Piece of cake.
    Grab a bucket, and a fire extinquisher (just in case). Disconnect the battery.
    Spray the fittings with PB blaster (or other penetrant) and let it soak for a good 15 minutes. Spray a day ahead of time if you can.
    Get the proper tools and preferably a flare wrench of the proper size. The flare wrench will help prevent 'rounding' of the fittings.
    After you break loose the fittings - stop there temporarily. Follow the hard lines from the filter to the connection points on the body. Disconnect these on both ends. This will give you the flexibility to get the filter out easily once you disconnect the fittings.
    Go back to your filter, disconnect the fittings (capture the fuel in bucket), replace filter, clean the ends of the fittings before re-attaching, and don't forget to re-attach the lines to the body. Re-connect battery, start the truck up, check for leaks. Continue to check for leaks in a few days or so.
    Your biggest concern in the whole process, is NOT TWISTING OR KINKING the fuel line.
  6. May 16, 2010 at 2:49 PM
    .Trdtaco315.
    Will
    Santa ana
    alright that does seem pretty simple. im gunna give it a shot. thanks!
