Changing out King Coilover Spring
Discussion in 'Suspension' started by Solution.45, Sep 29, 2016.
  1. Sep 29, 2016 at 1:00 PM
    Solution.45
    Solution.45 [OP] Well-Known Member
    Chase
    Redding CA
    2011 White 4x4 double Cab
    Does anybody know the best and easiest way to swap out King Coilover springs? I need to switch from a 14"x600lb to a 700lb coilover spring due to my plate bumper being so heavy. Any videos or pictures of taking the shocks apart etc will help alot. Or else I will just have to take it to a shop......
  2. Sep 29, 2016 at 5:33 PM
    Dajeepman
    Dajeepman Well-Known Member
    Andrew
    Pittsburg , Tx
    2006 Gold Tacoma base 4x4
    I take mine to a shop.. but you could go to autoparts store and get a external spring compressor and do it yourself. I've done them on my outback when I installed my lift springs.
  3. Sep 29, 2016 at 5:46 PM
    Solution.45
    Chase
    Redding CA
    Ive used a spring compressor before as well but my issue is getting it off the shock. I cant seem to find anything that shows how to remove the shock bottom....
  4. Sep 30, 2016 at 4:11 AM
    Dajeepman
    Andrew
    Pittsburg , Tx
    It's usually 1 bolt at the top that holds the spring on.
  5. Apr 5, 2017 at 10:33 AM
    GARSHA91
    GARSHA91 YES, that is me on that Facebook group
    Chicago
    2015 TRD Off-Road DCSB
    Just a grocery getter
    Were you able to do this? I'm about to do the same but I have resis and need to figure out how to do it
  6. Apr 6, 2017 at 8:15 AM
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
  7. Apr 6, 2017 at 10:16 AM
    GARSHA91
    Chicago
  8. Apr 6, 2017 at 10:31 AM
    TMFF
    Tim
    Thornton, CO
    01/02 DCLB
    compress the springs, you'll figure out how the lower seat slides off.
    It's not rocket surgery
    GARSHA91[QUOTED] likes this.
