Changing out most of front end. Am i missing anything?
Discussion in 'Technical Chat' started by S13chris, Sep 21, 2017.
  1. Sep 21, 2017 at 5:18 AM
    S13chris
    S13chris [OP] Well-Known Member
    Jacksonville nc
    07 dbl cab 4x4
    Tail gate mod, debadged, and weather techs, satoshi grill, diff breather mod, Duratracs 265/70/17, snugtop shell w/ rack, sleeping platform for bed, LED's for interior lights/Reverse lights/license plate, BHLM & DTRL Mod.
    Ok, so getting back from deployment at the end of the month and I have a lot of work to do on the truck. I pretty much need to replace everything on the front end that holds grease. So right now I have on the list Driver/Pass CV axles, Driver/ Pass Wheel Hubs assembled, both seals for the CV axles, ECGS Driver Bushing (replaces the needle bearing), Crush washer for drain plug, 1.5 qt of diff fluid, Tie rod ends, Sway bar ends, Upper/Lower control arm ball joints. Is there anything im missing, so I can knock everything out at one time? Or anything I should change out while everything is apart?
  2. Sep 21, 2017 at 5:26 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    Might as well grease those cam bolts if you havnt already​
    S13chris[OP] and GDT like this.
  3. Sep 21, 2017 at 5:31 AM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    Use oem parts. What about ball joints?
    S13chris[OP] likes this.
  4. Sep 21, 2017 at 5:32 AM
    S13chris
    Jacksonville nc
    07 dbl cab 4x4
    Thanks, Is it the same zerks as on the drive shaft?
  5. Sep 21, 2017 at 5:34 AM
    S13chris
    Jacksonville nc
    07 dbl cab 4x4
    I was going to us as many OEM parts as possible. Ball joints too, I forgot to put them on the list.
    JayRolla[QUOTED] likes this.
  6. Sep 21, 2017 at 5:37 AM
    ChadsPride
    We just pulled mine when doing the suspension and greased them via pointer finger
    S13chris[QUOTED][OP] likes this.
  7. Sep 21, 2017 at 5:40 AM
    S13chris
    Jacksonville nc
    07 dbl cab 4x4
    Will certainly do. I guess the lifetime alignment is going to come in handy.
    Dalandser likes this.
