changing rack guide on aftermarket rebuilt steering rack
Discussion in '1st Gen. Tacomas (1995-2004)' started by Burro, Oct 20, 2023.
  1. Oct 20, 2023 at 8:20 AM
    Burro
    Burro [OP] Well-Known Member
    SoCal
    98 v6 4x4 xtracab
    Hello TW.
    Has anyone updated the steering rack guide to the newer style on a rebuilt/ aftermarket rack?
    I'm assuming all the parts will fit since the rack housing and parts are all the same, it's just the seals and a few small things that get changed?
    Mine isn't stamped toyoda and i'm not sure when it was replaced, but sometime prior to me buying the truck 5 years ago. However it does appear pretty clean and may have been changed right before I got the truck, or it may have a ton of miles on it ‍♂️. It is not currently leaking.
    I just replaced the ITREs, OTREs, 333 fab clamp, and new rack bushings. I'm going to order a new rag joint, but was wondering if it's worth updating to the new style guide or if it's throwing money away. Should I wait until this one fails and get an OEM rack w/ new guide included?
    My goal is to get back to a stock + feel with poly bushings, and the new rack guide. I am okay with it being a little harsh, I just need it to be accurate and predictable.
    I currently have issues with bump steer, a feeling of looseness and a slight clunk. I also have a pull to the right that hasn't changed with any alignment I've gotten.
    I went under the truck last night and had someone turning the wheel. The whiteline LCA bushings will be getting replaced as well since they have play. They only lasted 3 years, not sure if that's typical or not for poly. I'll be switching to the strongflex bushings.
    I wheel the truck and do high speed desert roads a fair amount, but it's also my daily.
    Thanks for your thoughts and expertise.
  2. Oct 20, 2023 at 8:52 AM
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    Kinda seems like you should've sprung for the OEM rack rather than throwing all the money for ITREs, OTREs, and bushings at this one. But I'd probably just suggest the new rack at this point. Eventually they're bound to stop even selling the remanned racks for our trucks. They've already discontinued several other parts, so I'd spring for the OEM rack sooner rather than later, and down the road you can get it rebuilt by a company that does that kind of stuff (assuming your plan is to keep the truck long term).
  3. Oct 20, 2023 at 9:04 AM
    Burro
    SoCal
    98 v6 4x4 xtracab
    You're absolutely right about that. I guess that's the issue with trying to save money and going piece by piece. At least I can pull the ITREs off this one and save them for later once the others go bad off the OE rack.
    Is there still a possibility of getting the non updated guide rack off an online Toyota parts website or will they only have the updated one? I want to make sure it comes with the solid guide
  4. Oct 20, 2023 at 9:12 AM
    Red_03Taco
    Jerad
    I don't know for sure if you can get the earlier version or not. I kinda doubt it. Maybe you can find an earlier version in a junkyard or on eBay and then either rebuild yourself or send it off to be rebuilt, since you're not necessarily in need of a replacement immediately.
    Or just buy the updated guide version (new/remanned from Toyota) and retrofit it with the older style guide?
  5. Oct 20, 2023 at 9:47 AM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
  6. Oct 20, 2023 at 9:58 AM
    Burro
    SoCal
    98 v6 4x4 xtracab
    My bad, I meant to avoid the old one. I don't want to accidentally get the non updated one. Do you know what the new part number is by chance?
  7. Oct 20, 2023 at 10:08 AM
    O'Silver_Taco
    MD
    Burro[OP] likes this.
  8. Oct 20, 2023 at 10:24 AM
    Red_03Taco
    Jerad
    Try using partsouq.com and enter in an '01 or later Tacoma. Then it provides interactive parts diagrams and when you click on the part (in this case steering rack or rack guide) it brings up part numbers. Then for good measure I always cross reference that part # with another reputable online parts retailer such as TototaPartsDeal or McGeorge Toyota. I've yet to order an incorrect part since I started doing this
  9. Oct 20, 2023 at 10:40 AM
    Burro
    SoCal
    98 v6 4x4 xtracab
    I found this part number on the adventure taco website, thanks @turbodb
    TOYOTA Genuine OEM Power Steering Rack (44250-35042)
    From every photo I've seen of that particular part number it looks like the updated (recessed) solid style guide.
    turbodb likes this.
  10. Oct 20, 2023 at 2:38 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Yep that part number will always get you the new (preferred) rack. Works great on all 1st gen Tacomas. For anyone who finds this thread, here's the step-by-step with parts and tools needed for replacing the rack:
    Step-by-Step: Replacing the Steering Rack on a 1st Gen Tacoma (or 3rd Gen 4Runner)
    :thumbsup:
    Burro[QUOTED][OP] likes this.
