Changing Rear end gear ratios
Discussion in 'Technical Chat' started by hwy17cruzer, Jul 30, 2010.
  1. Jul 30, 2010 at 10:14 AM
    hwy17cruzer
    hwy17cruzer [OP] Member
    Santa Cruz, Ca.
    06 Taco 2.7
    swaybar
    Tacoma Forum; I just hop'd over from the towing section, and I'm new. I'm researching changing the rear end gearing in an 06 Tacoma 2wd 5sp 2.7ltr access cab. Looks to be a A05A Rear end according to the plate. According to my research on the web that'd be a 3.15 ratio. I think that's the highest offered? So to get more low end oomph at the boat ramp how low should I go? Looks like 3.42, 3.58, 3.91, 4.10, 4.30, 4.56 are offered as available options...... I'm thinking a real Granny gear for 1st and boat ramps, then use 2nd-5th for commuting like a 4 spd. Is this a reasonable idea?
  2. Jul 30, 2010 at 10:36 AM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    From what I've found aftermarket gears start at 4.56 and go up. If you can find a used set from another 2nd gen Taco that opens up your options to 3.31, 3.58, 3.73, and 4.10.
    5 lug w/manual tranny: 3.31
    5 lug w/auto tranny: 3.58
    6 lug 4cyl prerunner or 4wd: 4.10
    6 lug v6 prerunner or 4wd: 3.73
    I've heard it said that the 3.73 and 4.10 gears won't fit in the 5 lug carrier, so the only way to run those ratios would be to get a fully assembled third member from a 6 lug. This has been disputed and I'm not sure if it is actually true for the 2nd gen tacomas.
  3. Jul 30, 2010 at 1:31 PM
    hwy17cruzer
    Santa Cruz, Ca.
    06 Taco 2.7
    swaybar
    So on my 5 lug I presume I then have 3.31 and3.58 as sure options?
    Hey, 5 lug refers to the lug nuts on the wheel hubs right?
  4. Jul 30, 2010 at 1:41 PM
    afd23a
    The Dynamo of Dixie
  5. Aug 2, 2010 at 11:27 AM
    panacea
    panacea WESTCHESTER SALTY TACO
    Ivan
    Miami,Florida
    2009 XRunner Black Sand Pearl
    6000k HID,3000k HIDfog,TRD Cold Air Intake, Redline Struts, TRD Short Shifter, SOS Drop Kit,TR Front Brake Kit 332mm Rotors, SSteel Lines,1" Throttle spacer, Sway Bar Bushing Kit, Amsoil Engine and Tranny, K&N Big Oil Filter
    I have an 07 prerunner sr5 2.7 5 speed 6 lug and would like to install a 3.15 according to my vin I have 3.73 and I dont like it and would like to change it
  6. Aug 3, 2010 at 5:46 AM
    hwy17cruzer
    Santa Cruz, Ca.
    06 Taco 2.7
    swaybar
    Lower Rpms; What are your operational RPMs ? I'm thinking of the 3.58...
  7. Aug 3, 2010 at 3:54 PM
    panacea
    Ivan
    Miami,Florida
    I will be dropping in an Alpine Supercharger and I want to cruise below 2000 rpms at 70
  8. Aug 3, 2010 at 4:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    The 2.7's have a 4.10 ratio
