Changing Rear Tail Light Bulbs
Discussion in 'Lighting' started by alankt, Jan 17, 2011.
  1. Jan 17, 2011 at 7:55 PM
    alankt
    alankt [OP] Member
    Alan
    Honolulu, HI
    04 PreRunner TRD
    tires and rims, retrax cover, alarm
    How do I change the bulbs (stop, turn signal, back-up) on my 04 Tacoma? I removed the entire unit but it seems like it's just a matter of twisting and removing the old bulbs. Do I have to remove the plastic lens from the housing in order to have access to the bulbs? Thanks for your help.
  2. Jan 18, 2011 at 1:24 AM
    supremetaco2
    supremetaco2 Well-Known Member
    concrete jungle, oahu
    04inacoma
    +hp, lifted, lights, dif breather mod, debadged, shorty antenna...
    welcome to TW! once u remove the screws take off the entire thing and you should see plugs running into the back of the light housing. no need to take off the plastic lense although wen i took mine off it just kinda detached from the housing lol. just twist the back of the bulb to the right i think and you jus pull it out, then u can jus pull the bulb out and replace.
  3. Feb 18, 2012 at 8:21 AM
    BunnyUp
    BunnyUp Member
    Bellingham, WA
    2004 Tacoma SR%
    Did you replace the factory tail, stop and turn signal bulbs with bighter bulbs? What brand? Hapy?
