Changing Rotors and Keeping Current Pads?
Discussion in 'Technical Chat' started by GP100, Jul 1, 2013.
  1. Jul 1, 2013 at 7:55 PM
    GP100
    GP100 [OP] Well-Known Member
    Paul
    RI
    '06 TRD Offroad
    At about 65K I changed out brake pads and had the rotors turned. Shortly thereafter I started getting pulsations when braking. I can feel the pulsations in the steering wheel too. I'm assuming that the rotors are warped. I've been driving on them for quite a while (just turned 90K today.) I probably should have done this sooner but I'm thinking about replacing the rotors. Will there be an issue if I keep my current pads and just change the rotors? Is there something special I'd need to do to bed-in the pads/rotors? Also, any tips to compress the pistons in the calipers if I don't change the pads?
  2. Jul 1, 2013 at 8:02 PM
    WHPLSH3
    WHPLSH3 Fortified with horsepower-adding goodness...
    Vance
    Alberta
    Supercharged Spruce Mica 6spd 4x4
    Build thread coming soon!
    If there's still lots of life left on the pads and they've never been glazed, you should be ok. "Bedding in" brakes is for pads, not rotors.
    To compress the piston back in the bore, crack the bleed screw first. You should never back flush brake fluid through the system. You shouldn't need to bleed the brakes if you do it properly
  3. Jul 1, 2013 at 8:04 PM
    blakes09
    blakes09 Toyota Tech..when im not Fishing
    Blake
    Deep South
    4x4
    i would put new pads on it
  4. Jul 1, 2013 at 8:19 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I would not use the old pads.
    Bedding-in-brakes is for both the pad & the rotor. Whatever rotors you buy, ask the manufacturer for bed-in procedures. The manufacturer will never want to bed new rotors with used pads.
    Use a large C-clamp to compress the calipers. When I did mine this past spring (turn & new pads), I didn't need a c-clamp, as they compressed rather easily/freely by hand.
    I would think its unusual to warp the rotors in less than 30K miles - but that depends on how thick your rotors were after they turned them at 65K.
    Do you do a lot of hard braking? Have you hit any big potholes lately? Are your wheels torqued properly?
  5. Jul 1, 2013 at 8:45 PM
    WHPLSH3
    Vance
    Alberta
    Janster is right. Rotors do have a bed in procedure to start their long thermal cycle lifespan properly. And yeah, no manufacturer would ever recommend using old pads on new rotors.
    However...
    Unless you are going to put new OEM rotors paired with new OEM pads, the lifecycle will probably be less regardless of what you do. Unless you step up to Brembos or some other ultra high performance system.
    I've learned over time that OE rotors basically never warp if they aren't abused. OE brakepads are also the best compromise of low dust + high friction coefficient.
    Think about it: unless you work for Motor Trend or something and can do instant back to back tests of new vehicles, no one has ever thought the brakes on their new car didn't stop well enough
  6. Jul 1, 2013 at 9:04 PM
    LocoTaco
    LocoTaco Well-Known Member
    Don
    Central Washington
    09 SR5 TRD Sport
    I have to ask...
    Why do you want to reuse the pads?
  7. Jul 2, 2013 at 4:31 AM
    GP100
    Paul
    RI
    '06 TRD Offroad
    Gotta start taking my furlough days starting next week and $$ will be a little tight for one, and I figured if the old pads aren't worn down and look to be in good shape that maybe I could save a few bucks. I suppose I'll just change them out though.
  8. Jul 2, 2013 at 5:32 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    Long term I would do new pads with new rotors. Save up and do it together. Pads are relatively cheap to buy.
  9. Jul 3, 2013 at 5:18 PM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2021 TRD OFFROAD 4x4
    unless the wheel is jerking out of your hands while braking let it ride. New rotors and old pads is akin to taking a shower and putting dirty clothes on.
    Furloughs suck but our leaders are having a great time. I'm in the same boat as you.
  10. Jul 4, 2013 at 2:48 AM
    Janster
    Jandy
    Lancaster, PA
    No offense, but I wouldn't recommend letting it go until it gets that bad. I'm pretty sure it can have a negative effect on wheel bearings, tires, wheels, steering, and overall safety.
    The last thing you need to do, is turn a $200 job into a $1000 job later on.
    Just sayin....
  11. Jul 4, 2013 at 3:16 AM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    Pads are inexpensive and after 25k, ditch them...and I go on furlough next week also, and I think it is great, since I work 4x10, I will have four day weekends all summer. The only question I have yet to get answered is which 20% of my assigned workload to I ignore?
  12. Jul 5, 2013 at 3:49 AM
    BUZZCUT
    Georgia
    :spy::spy::spy:
  13. Jul 5, 2013 at 4:34 AM
    monstertaco12
    monstertaco12 Quack Addict
    Louisiana
    2012 Taco TRD Off Road
    Pads are cheap. Change em out...
  14. Jul 5, 2013 at 5:03 AM
    Reeeno403
    Reeeno403 hammerdownson
    Calgary
    06 Tacoma
    Not a Stocko Taco.
    Never NEVER try to save money or time on brakes.....unless you carry a large rope and anchor. What else is left to stop your truck besides another vehicle, person, or building.
    Change them out
  15. Jul 5, 2013 at 5:17 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I'm not gonna lie, the stock pads and rotors combo was horrible. They would constantly warp and would not provide strong braking. The combo I replaced them with has been leaps and bounds better.
    I'd go against the grain, if your pads have a lot of life left in them, I see no reason to change them out. Make sure they're worn evenly all around and have at it. I've replaced rotors without changing the pads and replaced pads without replacing rotors, there's no safety concern if all the parts are in good working order and there is plenty of wear left on the part you didn't replace.
  16. Jul 5, 2013 at 7:31 AM
    snoope
    snoope Well-Known Member
    Winter Haven Florida
    2002 Tundra Limited 4x4
    Just my 2 cents;
    If those rotors are acting up, what do you think those pads are doing.....trying to "make up" for those waves that keep slapping them...
    Sorry for the furlough BUT please save up and do the whole process A NEW.....those used pads might last 3 weeks or 12 months BUT when they go, you're right back to square one...;)
