changing rotors and pads ?
Discussion in '1st Gen. Tacomas (1995-2004)' started by sunflower, May 4, 2012.
  1. May 4, 2012 at 11:41 AM
    sunflower
    sunflower [OP] Well-Known Member
    Is there anything I need to know about changing brake rotors and pads in a 2002 Tacoma thats special ? I have done them numerous times in Fords and Hondas but never my Tacoma.
  2. May 4, 2012 at 12:51 PM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Nope. Easiest maintenance you will do on this truck. Check out the DIY thread on top for some how-to's if you need but otherwise its just two bolts per side.
  3. May 4, 2012 at 3:03 PM
    bpkrules
    bpkrules Well-Known Member
    Jon
    Houston
    Tacoma4x4 BATMAN
    ARB Front bumper. Custom rear bumper. ARB snorkel. 883s 90004s. 1 inch daystar body mounts lift. Full skids. Leather seats.
    There is a great "how to" on Youtube.
  4. May 4, 2012 at 5:59 PM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    These youtube videos pretty much explain everything. Seems very simple to me, and I am terrible with this kind of stuff, lol. I'll be doing it soon. Let me know how it goes.
    Part one
    Part Two
  5. May 4, 2012 at 6:01 PM
    Madjik_Man
    Boulder, CO
    1998 Ext Cab 4x4 TRD 5MT sunfire red pearl
    About 25 pounds of spray paint and vinyl dye
    So I'm gonna be the new breed of "hipster doofus" mechanics.
    Next to me on the driveway will be my Macbook Pro with the youtube tutorial guiding me the whole way through the process
    :eek:
  6. May 4, 2012 at 8:33 PM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    ^ Thats generally how I do it. Manual on one side and internet on the other.
  7. May 5, 2012 at 8:37 PM
    TacomaJPP
    TacomaJPP To secure peace, is to prepare for war
    East TN
    03 4WD TRD XTD Cab
    Snugtop Camper Brushguard
    Just a note, if you end up only doing pads, you don't even have to remove the two caliper bolts. Literally, pull a spring retainer, two pad dow pins, and you're ready to remove the pads. It's awesome.
  8. May 6, 2012 at 9:49 AM
    Madjik_Man
    Boulder, CO
    Forgive my ignorance, but if you're just changing your pads, don't you have to resurface your rotor also (or whatever it's called)?
  9. May 6, 2012 at 9:54 AM
    snoope
    snoope Well-Known Member
    Ft.myers,FL
    2003 Lexus ES300/2004 Lexus 330 AWD
    If you are doing "IT" the right way and only want to be there once..YES....;)...
    This may be a moot point BUT depending on your miles and the price of rotors,just purchase everything NEW :cool: and be done !!!!
  10. May 6, 2012 at 9:58 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    When I replaced my pads I used Dura Last, the resurfacing cost was only a few less than new rotors, and I got a $10 rebate on the rotors.
  11. May 6, 2012 at 1:08 PM
    Robertgeejr1
    Robertgeejr1 Well-Known Member
    Robert
    Aorora, Ill, yeah!
    1996 Toyota Tacoma SR5 4x4
    I have done all the hi-pro mods for a life time, since I got this truck at a great price, I will be happy with showroom new.
    yes, while you are doing it you should just go ahead and install new rotors. I got blasted for saying this awhile back, but while rotors can be resurfaced, (if not worn too bad, that is just looking at the surface. rotors are subject to mico cracks and metal fatigue, and they are a little thinner then you resurface them, so why take a chance? They don't fail often, and yes its rare, but if you are off roading, have a load in your truck, would you want to take a chance for it to fail then? esp. for something so simple. sometimes saving 20 dollars per side, is not worth it. and think about it this way, if you are doing it yourself, like changing the oil, look at all the labor money you are saving, put some back into your truck and you are still ahead of the game.
  12. May 6, 2012 at 6:32 PM
    TacomaJPP
    East TN
    03 4WD TRD XTD Cab
    You don't have to. However, I highly advise turning the rotors when changing the pad. If you don't, it seems the pads don't last as long, your stopping power isn't as good, and I think you have a higher chance of grooving the rotors.
  13. May 6, 2012 at 9:05 PM
    Robertgeejr1
    Robert
    Aorora, Ill, yeah!
    when doing brakes, you need to at least turn the rotors. I have had many years experience with this, and no one I know who works on cars or trucks would ever tell someone straight up, you don't need to at least turn the rotors when doing the brakes. Its unsafe. I will take a stand on this with anyone, anytime. And I welcome any discussion on this.
