changing speed sensor's gear
Discussion in '1st Gen. Tacomas (1995-2004)' started by blacksheff405, Jan 9, 2012.
  1. Jan 9, 2012 at 8:58 AM
    blacksheff405
    blacksheff405 [OP] no one ever pays me in gum
    caleb
    north carolina, concord
    02 dbl v6 12' lift on 38's
    lift kit (12'), super swampers 38's, brush gard, kc's , sub, amps, high end audio equipment
    Wasn't sure exactly where to place this and after searching around i couldn't find anything really helpful. but i digress
    in order for me to pass the inspection my gear needs to be switched out but I have no clue where it is and how to do it :eek:.
    So any help will be very much appreciated .
  2. Jan 9, 2012 at 9:41 AM
    Southern01Taco
    Southern01Taco Well-Known Member
    Sean
    Holden, La
    01 V6 4x4 Xtra Cab SR5
    I'm guessing you need to do this to correct your speedometer for big tires. It's not as easy as changing a gear. The speedometers are sensors not gears. Most people, including myself, just use a gps, scangauge, ultragauge, or something similar to show the correct speed. I read somewhere that dakota digital has a universal control box that you either plug in or hard wire in and it corrects the speedometer somehow. Not to sure on that one though.
    edit: My mistake. After a quick search, it is a gear and here is a thread that shows what you need.
  3. Jan 9, 2012 at 9:52 AM
    blacksheff405
    caleb
    well i have the part i just need to know what to do.. never done anything like this and completely clueless i'm bout to go out and look at it to see if i can figure something out
    thanks for the help though
