Changing Stock TRD OR Tires for Falken WildPeaks
Discussion in 'Wheels & Tires' started by Kernel Panic, Jul 19, 2022.
  1. Jul 19, 2022 at 6:10 PM
    Kernel Panic
    Kernel Panic [OP] Member
    2020 Tacoma TRD 4x4 Off-Road
    Hey all -
    Wanting to change out my 2020 TRD OR 4x4 GY Wrangler's for some Falken WildPeak A/T3W's. Staying with the stock sizing 265/70R16, as this is my daily driver and is our fam's long-range trip vehicle.
    My main question is: the 265/70R16 Falken WildPeak looks to only come in an SL tire which, I believe, is only 4 ply. Does the stock Goodyear Wrangler All-Terrain Adventure with Kevlar have a "stronger" tire in terms of ply for punctures? I believe it's an SL tire as well from what I can find on it. The GY website seems vague and the sidewall lists the ply info as 2 in the tread with extra in the "steel kevlar"...
    I guess I'm wondering if, in terms of punctures, it would've been better to go with a tire that was C or E class load rated... I think the BFG KO2 in that size is already E class load rated. I've read more on tires in the last few weeks than I ever thought I would lol, so be kind - I'm new haha
  2. Jul 20, 2022 at 10:16 PM
    Raijin822
    Raijin822 Well-Known Member
    Canada
    2021 TRD OR
    Stick with p rated if your not doing rock crawling or lots of off road where you need to air down heavily. Your wallet will thank you as C and E are HEAVY tires
    C and E rating is more of load rating for heavier vehicles. It just so happens to be bit sturdier but that doesn't mean the falken p tires are by any means weak
    You can run slightly bigger 265/75r16 at stock height with no issues. Fills in the wheel wells better too.
  3. Jul 20, 2022 at 10:20 PM
    ill ay
    ill ay I DO MAN STUFF
    The Valley
    2012 Pre Tacoma & 2017 4x4 SR5 Tacoma
    I believe C load is the happy medium as you can use them for daily driving but then use it for needed work. Don't get a loaded E rated tire.
  4. Jul 25, 2022 at 10:29 AM
    Kernel Panic
    Thanks all - I put the Wildpeaks on, and so far they've been great. I get the same mpg as the GY's, and they do look much more aggressive so for ascetics it's good too.
    I'll see the off-road performance soon enough, but for road/looks, the Wildpeaks seem great
