changing struts......
Discussion in 'Suspension' started by brelandt, Apr 22, 2011.
  1. Apr 22, 2011 at 7:37 PM
    brelandt
    brelandt [OP] Well-Known Member
    Terry
    Dublin, CA
    04 Prerunner reg cab SR5
    3" lift front and back
    I am expecting my new KYB monomax struts to match my rear set I bought last week. I just bought a strut spring compressor but here is where I may need some help.
    I know how to remove the strut and coil assembly from the truck but I have never removed the strut from the coil.
    Is there something I need to know about removing the center nut and top plate and reinstalling it?
    Is it better to break the torque on the center nut while it's still on the truck?
    Just need to know this before I have the unit sitting on the workbench. Thanks! :cool:
  2. Apr 22, 2011 at 10:00 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    YES !! A couple things buddy, FIRST & FOREMOST Do NOT REMOVE CENTER NUT UNTIL YOU SAFELY & CORRECTLY COMPRESS COIL SPRING !!
    Please take this serious, if you loosen & remove nut without doing the above action, you stand a more than likely SERIOUS , EVEN FATAL INJURY !! This is no joke bro'....
  3. Apr 22, 2011 at 10:46 PM
    brelandt
    Terry
    Dublin, CA
    is there a trick to getting the nut off? I am just seeing myself trying to break the nut off with the whole unit rolling around on the ground or falling out of the bench vise, LOL!
    Is there a area under the top plate I will need to place a wrench once the coil is compressed in order to loosen and tighten the center nut? Or is it just loosen the nut?
  4. Apr 22, 2011 at 10:53 PM
    woody6047
    woody6047 McGrubber
    Beau
    Austin/ Waco Texas
    05 tacoma 4x4 dc
    100%stock, except for the exhaust leak and custom windshield crack mod
    I havent done it for about 4-5 years, but IIRC first COMPRESS the coil, leave it compressed then just loosen the nut and it should come out.
  5. Apr 22, 2011 at 10:54 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    You pretty much just loosen it. Its not like a gorilla torqued that thing on there, it comes off pretty easy.
  6. Apr 22, 2011 at 10:57 PM
    brelandt
    Terry
    Dublin, CA
    sweet, I was hoping that was the case.
  7. Apr 22, 2011 at 10:59 PM
    eagle5521
    eagle5521 Member
    Scott
    Louisiana
    `11 PreRunner DCSB TX
    I guess you can call it a trick. you will need two wenches: one for the nut one to hold the the very top end still. It will turn with the nut once you start to remove it. Some struts will have a place for an allen wrench on the end, but the stock struts don't.
  8. Apr 23, 2011 at 1:25 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    You can loosen the center nut while the strut is still in place, just don't take it completely off, that nut holds the spring preload & is under extreme pressure, example: our springs are roughly , what, about 550-650lbs, meaning it takes (550-650 lbs)of pressure to compress the spring 1", the preload is about 2", so you remove that nut without first compressing it you have about a 20lb chunk of coiled steel coming at your face with more than 1/2 a ton of pressure behind it, released in the blink of an eye... at a range of maybe 2ft..:eek::eek::eek::eek::eek::eek::eek::eek::eek::eek::eek:
    you can figure out the rest, ( coil spring replaces head)
    so please be careful man, & another thing, I've changed out about 5 coil over struts & everyone of those compressors will look like there going to come apart on you, they bend,they twist, they warp out of shape, believe it or not this is normal. It's not a hard job, but it is a spooky one that is unforgivable if you fuck up, so,, ya know,,, don't fuck up, & good luck !!;);)
  9. Apr 23, 2011 at 9:02 AM
    brelandt
    Terry
    Dublin, CA
    I promise you Doug I plan on keeping my head!!! LOL
    I bought the $35 compressor from Kragen/O'reilly's auto. It looks like crap so I am expecting it to bend and sound strange......However, no need to buy a $50 one from Sears since I may only use this thing once a year or so?
    Never made it to the pick a part this week. maybe next week, but my plans are changing with what I want to do with my truck.
    Thinking of the same leaf set up as your and getting rid of my bed cap that does even fit my bed! then maybe a shaved front bumper and prerunner style lightbar? Some guy down the street has a full caged f-150 prerunner that just looks bad ass!
  10. Apr 23, 2011 at 9:12 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Ok just remembered that you can use an open end wrench (don't remember the size) to hold the stud while you loosen the nut.
    also ditch that compressor and rent one for free at autozone, I think you put like a $50 deposit that you get back when you return it. Here's a pic of the autozone compressors.
  11. Apr 23, 2011 at 9:30 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Nice !!.....;) & I'll add if there is anyway possible get an air impact or electric impact for the compressor, it'll turn a 3 hour pain in the ass (compressing by hand) into a 10 - 15 min. cake walk..... Oh yeah I started building some springs last night for a member (Matt -RecklessTaco) so he'll be ready to do a Mojave desert trip coming up in SoCal in about a week or 2 I think, be sure to post up pics Terry....;)
  12. Apr 23, 2011 at 9:48 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Make sure the compressors are lined up with eachother or they will slip and come loose. Alternately tighten them evenly and be sure to lube the screws, or they will gall. Do not place anything of value in line with the spring's line of travel.
    The safer, quicker alternative would be to take the CO Assy out and take it to a shop to have them changed out. They have a nice, wall mounted, safe coil compressor.
  13. Apr 23, 2011 at 11:18 AM
    sac130e
    sac130e Well-Known Member
    Scott
    Milton, FL.
    11' TRD Off-Road 2wd
    JVC Nav. System and entire Memphis Audio Speakers/Amps
    Does the 1/4" spacer for the taco lean og on top of the top plate or under it?
    About do try this next week for my lift
    Scott
  14. Apr 23, 2011 at 1:19 PM
    Largefarva
    Largefarva Well-Known Member
    Fox Lake, IL
    '08 Double Cab TRD Off Road 4x4
  15. Apr 23, 2011 at 8:12 PM
    brelandt
    Terry
    Dublin, CA
    sweet info guys..just got to my parents house and the struts arrived. Now that I have them in my hands I see there is a square notch on the top to place a wrench.
    When I drove over the speed bumps going into my neighborhood I noticed the front bounced twice and the rears never bounced at all! Can't wait to see the difference with these KYB!
  16. Apr 23, 2011 at 8:18 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Thats great Terry, I've always liked KYB shocks, they were the first gas shocks I'd ever seen, very solid, very established company....;)
  17. Apr 24, 2011 at 7:36 AM
    brelandt
    Terry
    Dublin, CA
    doug when I got the box I was shocked (no pun intended) at how light the box was. I was like all crap they sent the wrong thing! But after I opened it sure enough there was 2 struts in there. I think my rear shocks are heavier?!?!?
    I couldn't sleep all night! can't wait to put these bad boys on!
  18. Apr 24, 2011 at 7:43 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Just like Christmas huh...:D, post up some pics when yer done dude !!
  19. Apr 24, 2011 at 7:47 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    The rear struts are longer, so there is a good chance they are heavier...
  20. Apr 24, 2011 at 7:53 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Happy Easter Christopher, time to kill a bunny ??:eek::eek:
