Changing tailgate. Can't loosen Torx screw on hinge.
Discussion in '1st Gen. Tacomas (1995-2004)' started by umpire3, Jan 23, 2022.
  1. Jan 23, 2022 at 2:18 PM
    umpire3
    umpire3 [OP] Well-Known Member
    Robert
    2004 Tacoma 4-door, V6
    Bought a new tailgate shell and changed over all mechanisms from the old to the new. I can't break loose the T-40 Torx bolts on the hinge. I broke the T-40 and the bolt never broke loose. In fact it damaged the Torx splines. I had to drill it out. That's one of 4.
    Anybody have a successful way on loosening these bolts?
    2004 D-cab PreRunner with V6.
  2. Jan 23, 2022 at 2:23 PM
    Catcrazed
    Catcrazed Love is Dogs and Toyotas
    Bryan
    Central Oregon
    3rd Gen Flatbed 3.4
    91 Flatbed, 4.88's, ARBs, SAS, 3.4 Swap, 35s, M8000, lots lights, Aux tank, Protech
    Wulf likes this.
  3. Jan 24, 2022 at 6:17 AM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    spray with 50/50 mix of acetone and automatic trans fluid. Let it soak for a few days, repeating spray periodically.
    RattleTractor likes this.
  4. Jan 24, 2022 at 6:51 AM
    02hilux
    Planet: EARTH
    Impact driver?
  5. Jan 24, 2022 at 10:25 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    yup- pb blaster + impact driver.
  6. Jan 24, 2022 at 10:41 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    I only buy impact Torx Sockets in the larger sizes
    Soak with your favorite penetrating fluid for a day or so.
    hit with 1/2" impact if that does not break it loose bring out the torch.
    I feel sorry If you live in the liquid brine belt
    Good Luck
  7. Jan 24, 2022 at 11:06 AM
    Wulf
    Wulf no brain just damage
    rock raisin
  8. Jan 25, 2022 at 9:42 AM
    umpire3
    Robert
    Can't reach the bolt from the back side of the shell. Drilled an 1/8" right above where the bolt should be. Sprayed through the hole with PB Blaster. With a heavy duty impact drill I was able to zip one of three out. The other two I had to drill out.
