Changing the 5100's today!
Discussion in 'Suspension' started by MedlinAround, Mar 26, 2011.
  1. Mar 26, 2011 at 7:54 AM
    MedlinAround
    MedlinAround [OP] Failure is the result of letting setbacks stop you
    Cody
    Richmond, Kentucky
    2008 TRD off-road edition Tacoma
    Bilstein 5100's (.85), Eibach Coils, AAL, Magnaflow exhaust, Volant Intake, OKledlight pods, Front Skid Plate, 4% Tinted Windows, Weathertec Floor Liners, Double Din Pioneer Player, 2 10" Memphis SR Subs, Plasti Blacked out Bumper, Grill, & Emblems, Custom Bed Rack, TRD Nation interior LED dome kit, 4X innovations sliders, DIY Roof Rack, Storage - Rotopax, Pelican 1600 waterproof case, Plano 42"case.
    Puttin my 5100's on today with my dad. Anything I need to be aware or cautious about? A guy bought my stock shocks so it gave me a good excuse to have to change them out.
    My tires are worn bad and I'm in the process of getting new ones at the moment. Going with Eibach coils set at .85 also. Should I o ahead and set the shocks to .85. when I put them on or wait till I get tires and coils?
  2. Mar 26, 2011 at 8:12 AM
    TexAggie
    TexAggie Well-Known Member
    Eric
    Amarillo, TX
    OME Lift
    You'll need a coil spring compessor and make sure you put the plate on the shock correctly. Good luck!
  3. Mar 26, 2011 at 8:16 AM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    If you are going to put the stock springs on now and change to Eibachs later it is going to be a lot more money getting the springs compressed twice and an alignment after each.
    If you can wait till you get the springs then you can do it one time and save some money
  4. Mar 26, 2011 at 8:24 AM
    MedlinAround
    Cody
    Richmond, Kentucky
    Well I will prob be getting tires in the next week or so anyway so I was going to hold out on the alignment until then so I won't have to pay for it twice. So maybe I should just set it to 0 for now so I won't have to compress my springs?
  5. Mar 26, 2011 at 8:33 AM
    OH-MAN
    Sunny Az.
    10 4X4 O.R. White
    You will have to compress the springs to remove them from the shocks.
    Do not remove the big nut in the middle without having the springs compressed they are under a bunch of pressure.
    Read the how to before you start for your safety.
  6. Mar 26, 2011 at 8:34 AM
    MedlinAround
    Cody
    Richmond, Kentucky
    Alright. Cool thanks.
  7. Mar 26, 2011 at 8:36 AM
    OH-MAN
    Sunny Az.
    10 4X4 O.R. White
  8. Mar 26, 2011 at 8:37 AM
    TexAggie
    Eric
    Amarillo, TX
    OME Lift
    I rented a compressor from Auotzone for cheap, just call them and see if they have one for rent.
  9. Mar 26, 2011 at 8:39 AM
    OH-MAN
    Sunny Az.
    10 4X4 O.R. White
  10. Mar 26, 2011 at 10:58 AM
    MedlinAround
    Cody
    Richmond, Kentucky
    Ok well putting the back ones on you have the metal ring that came off the stock and the metal ring that was sent with the 5100's. The stock one has a little lip that sticks all the way up through the whole to put the nut on with and the 5100 ring doesn't.
    Does it matter and by looking at the stock setup it goes ring/black plastic piece/ring then through the hole black piece/nut... First time doing this so i wanna make sure i have it right the first time and not have to take it back off.
  11. Mar 26, 2011 at 11:34 AM
    David Tarantino
    David Tarantino Well-Known Member
    N.J.
    08 tacoma
    it should be washer bushing put the shock though the hole then
    put on the next bushing washer then nut
  12. Mar 26, 2011 at 11:53 AM
    MedlinAround
    Cody
    Richmond, Kentucky
    Gotcha.. Got her on, going to wait to do the front for now but so far i like the ride of the back pretty good!
  13. Mar 26, 2011 at 11:56 AM
    MedlinAround
    Cody
    Richmond, Kentucky
    Before i finally got the plastic pulled down the shock a little bit... Might be a dumb question but I've always wondered.. Why is one shock in front and one behind the axle?
  14. Mar 26, 2011 at 12:13 PM
    MedlinAround
    Cody
    Richmond, Kentucky
    Sure the guy knew anything about what he was talking about? Doesn't make any since to me.
  15. Mar 27, 2011 at 9:13 AM
    MedlinAround
    Cody
    Richmond, Kentucky
    Anybody else heard or had this problem?
