Changing the clutch
Discussion in 'Technical Chat' started by unitedairforce1, May 30, 2012.
  1. May 30, 2012 at 9:31 PM
    unitedairforce1
    unitedairforce1 [OP] Member
    Connecticut, USA
    95 Tacoma Ext. Cab
    American Racing Rims
    Hello! I've got a 1995 tacoma ext cab, inline 4. I need to get the clutch changed, and since i don't have a lift, nor the patients to do it on ramps/jack, i got a quote from a mechanic. The guy mentioned something about getting the flywheel remilled. Now, I'm a junior in highschool and I'm down in the autoshop every chance i get, and i've never heard of anyone having to get a flywheel removed. Now don't get me wrong, I know I don't know everything, but I just wanted to make sure he wasn't taking money from me, because I'm a young kid. Any thoughts?
  2. May 30, 2012 at 9:38 PM
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    Sometimes when you replace the clutch disc, it's because the disc wore out all the way into the rivets. That scores the flywheel which might make the new disc not grab as well or fail early. If this is the case, yes spend a few extra dollars to get it done right. If the clutch did not damage your flywheel, you can simply "scuff" the surface with 320 grit or finer to remove glazing then wash with brake cleaner and install a new disc, pressure plate, and throw out bearing.:D
  3. May 30, 2012 at 9:50 PM
    unitedairforce1
    Connecticut, USA
    95 Tacoma Ext. Cab
    alright, thank you very much! :)
  4. May 30, 2012 at 9:56 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    I would just get it resurfaced, clutch parts are not a thing you want to skimp on because it is the labor that costs the most.
  5. May 31, 2012 at 6:22 PM
    aptech
    aptech Jetfixer
    Adrian
    houston (angleton)
    10 dc offroad
    daystar level kit, tsb rear spring, ghostflames, sport hood, tsb steering, trd cai, red map lights. backup cam any time mod, fog light any time mod. bed light mod. 400watt inverter mod. 2857516 dura tracs. beach sand intsall
    better safe than sorry. especialy when your depending on some else to do it. trust no one :spy:
