Changing the direction of the "manual" option for the auto
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Charlie Don't Surf, Oct 27, 2019.
  1. Oct 27, 2019 at 5:26 PM
    Charlie Don't Surf
    Charlie Don't Surf [OP] Well-Known Member
    2019 SR5 QCSB Cavalry Blue
    I was lucky enough to drive a Lancer Evo with a sequential dog box tranny. Short version is the direction of up and down shifts are reversed on my Taco from what I like. Anyone ever have their auto selector out to see how it works?
  2. Oct 27, 2019 at 6:12 PM
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    It's not a manual option.
  3. Oct 27, 2019 at 6:16 PM
    Da Boogie Man
    Da Boogie Man Purple Nurple
    Seymour
    OOOOOOOOOWUUUUUUUUUUT?
    Navigator1, Chew and GreyBaldTaco like this.
  4. Oct 27, 2019 at 6:28 PM
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    I *think* I've heard of someone swapping orientation of that actuation on a Tacoma. But you'd want to make sure and update your guide indicators for 'others' driving your truck.
    Also, S mode isn't a true manual selector; it only sets the maximum gear. So unless you have OVTune and gear lock mode, it's a bit squirrelly to make it shift 'like' a manual.
  5. Oct 27, 2019 at 6:29 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Race truck
  6. Oct 27, 2019 at 6:31 PM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    Switch the red (pin 1) and green (pin 3) wires on the 5-pin connector going into the shifter and you'll have what you're looking for.
    As was said though, it's not really a manual shifter, and you should probably change the labels to not confuse anyone driving the truck, haha.
    Jeff
  7. Oct 27, 2019 at 6:31 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Make sure you do your steering wheel volume / track select at the same time.
  8. Oct 28, 2019 at 2:14 AM
    Charlie Don't Surf
    Hence the " " in the title
  9. Oct 28, 2019 at 2:16 AM
    Charlie Don't Surf
    that's up next
    Stocklocker[QUOTED] likes this.
  10. Oct 28, 2019 at 2:16 AM
    Da Boogie Man
    Seymour
  11. Oct 28, 2019 at 2:18 AM
    Charlie Don't Surf
    that's what I was hoping to hear before I took things apart. Thanks
  12. Oct 28, 2019 at 2:58 AM
    Charlie Don't Surf
    Is the OVT and gear lock the same program?
  13. Oct 28, 2019 at 4:56 AM
    RushT
    North Texas
    Yes and no. OVTune is an aftermarket ECU tune focused on improving the drivability of the Tacoma. Additional power and torque is a ‘ride along’ benefit.
    OVTune has various tunes, and one of them is a gear lock tune that changes the behavior of S mode. In that tune S mode behaves much like a manual selector for which gear to be in. It will stay in the chosen gear unless in danger of stalling, at which point it will downshift.
  14. Oct 28, 2019 at 5:05 AM
    Navigator1
    Navigator1 Assistant to the Regional Manager
    Spokane WA
    18 TRDORDCLBCEMENT
    This isn’t going anywhere good.
    Tainted and GreyBaldTaco like this.
