Changing the pinion angle...
Discussion in 'Technical Chat' started by Bearskill, Aug 14, 2009.
  1. Aug 14, 2009 at 5:14 AM
    Bearskill
    Bearskill [OP] Well-Known Member
    Sac
    06 Access cab PreRunner Sport
    FlowMaster 40 duals out the back, T-Rex grill, Color matched TRD Nerf bars, Icon coilovers set at 2'', 2.75" OME Dakars spring packs, OME Nitro-Charger extended rear shocks, Carrier bearing drop kit, Wheeler's Extended break Lines, Total Chaos UCAs, Mojave Teflons and 31 1/2" Toyo Open Country A/Ts, Pioneer single din unit, Yakima roof rack, Malone roof basket with X2 KC 130w long range Slimmlights mounted to it, Garmin 255w nav, Fire bottle mod, Air Force standard First Aid kit mod, Hidden Muchette mod (don't ask), and 1 huge OCD about my truck.
    I have been Talking with the guys at Tom Woods, and to put in the drive shaft I would like im told I will need to pitch my pinion angle 3 degrees. What is the best way to do this? Shim my axle? Are there other ways? What is the best most solid way?
  2. Aug 14, 2009 at 5:58 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Shim the axel. A 3* shim is commonly availible.
  3. Aug 14, 2009 at 7:27 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    X2
    I'd highly recommend getting steal shims.
    Alluminum shims tend to distort in shape over time.
