Changing timing belt. What else to do "since I'm already there"?
Discussion in '1st Gen. Tacomas (1995-2004)' started by coff33, Aug 7, 2021.
  1. Aug 7, 2021 at 10:16 AM
    coff33
    coff33 [OP] Well-Known Member
    5vzfe manual
    Planning on a 8-12 hour maintenance run. I want to gather supplies and make plans to make the most of this time. Take care of as many things as possible since I'll be already that deep in it. So much so that I wont have to go in there again for 2 years/30k miles.
    Truck has just under 200k on it right now and I don't know what previous owner did or not. Here's my list:
    . full coolant flush
    . new water pump
    . power steering pump rebuild
    . valve clearance check
    . spark plugs
    . plug wires
    . new valve cover gasket
    . complete starter motor inspection
    . complete alternator inspection
    . ac compressor removal (it's already unbelted)
    . new outer belts
    What else should I do?
  2. Aug 7, 2021 at 10:19 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    I would start with a coolant/exhaust gas & leak-down test to get an idea of the integrity of your head gasket; you'll already be half-way there, and if it's at all compromised, that's the time to do it. Otherwise, sounds like you've got all the key items nailed.
  3. Aug 7, 2021 at 1:04 PM
    JudoJohn
    JudoJohn Well-Known Member
    St. Louis
    96 Tacoma 2WD 5 speed
    X2 with tirediron.
    Why is your AC compressor unbelted? is the compressor bad? If so, please safely evacuate the freon.
  4. Aug 7, 2021 at 3:55 PM
    Nessal
    Nessal Well-Known Member
    Texas/Bay Area
    2003 V6 4X4 TRD DCAB
    PCV valve(make sure you have replacement rubber gromet)
    Cam seals if they are leaking
    Half moons if they are leaking
    Clean IAC
    Clean throttle body
    Spark plug seals
    Replace valve cover rubber washer with new ones.
  5. Aug 7, 2021 at 7:09 PM
    coff33
    5vzfe manual
    decided to remove ac altogther. already evacd. comp is the only thing remaining.
    1997tacomav6 likes this.
  6. Aug 7, 2021 at 7:43 PM
    1997tacomav6
    Denver
    This is a tricky situation once you remove the compressor because you have to have a perfect balance of Freon and the added oil amount when you refill it and there is probably oil in the compressor.
    Too much or too little oil will be problems
    JudoJohn likes this.
