changing tires from 245 to 265 or 275?
Discussion in 'Wheels & Tires' started by Asdfghjkl123, Jul 19, 2017.
  1. Jul 19, 2017 at 11:58 AM
    Asdfghjkl123
    Asdfghjkl123 [OP] 2010tacomadoublecabv6
    california
    2010 Tacoma double cab v6 sr5
    Oem
    If i change my tires to bigger sizes will my speedometer be totally off and if so will i be able to have that readjusted to have it read the correct speed and if so how much does that usually cost. Also how much does a dealership charge to have the TPMS reconfigured to accommodate for a bigger size tire?
  2. Jul 19, 2017 at 2:01 PM
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    I've read a lot of times the Tacoma's with 245 sized tires actually have a speedo that's off from the factory since it's calibrated for 265 sized tires. That could be heresy, just what I've read.
    You can have the speedo recalibrated or learn how it's off and adjust your driving accordingly. I'm not sure what the cost would be however.
    You can also use a tool like a scangauge to view the adjusted speed or something like a hypertech speedometer calibrater to fix it.
    http://www.autoanything.com/performance-chips/69A5754A0A0.aspx
    http://www.autoanything.com/performance-chips/61A3757A0A0.aspx
    The TPMS sensors don't care about what tire size so long as the air pressure in the tire is correct.
  3. Jul 19, 2017 at 2:04 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    That sounds accurate to me.. I have 265/75/16s on my four banger and got pulled over doing 78 (what the speedo read) in a 70. I was expecting the officer to tell me I was doing 10-12 over the limit but he said he clocked me doing 78. My taco came from the factory with 245's and when I went up to 265s, it seemed like the speedo was still on the money..
    eccracer104[QUOTED] likes this.
  4. Jul 19, 2017 at 2:05 PM
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    Thanks for confirming that :thumbsup:
    BassAckwards[QUOTED] likes this.
  5. Jul 19, 2017 at 2:12 PM
    BassAckwards
    No problem! Thanks for posting about the miscalibration from the factory. This is the first ive heard about the speedos being calibrated for 265s. Definitely makes sense though. I was wondering how I got lucky when I got pulled over. It all makes sense now! :thumbsup:
  6. Jul 19, 2017 at 2:22 PM
    tacoshin
    tacoshin Well-Known Member
    Brian
    the name of my truck, WA
    2008 Lexus IS250 AWD/2014 Tacoma SR5 4x4 short bed
    Smittybilt step bars, Toyota skid plate, All Pro bed rack w/ tonno pro retrofitted thanks to pushingcasket for helping, trd exhaust 14019 miles
    I was on 245, now switched to 265/75/r16 and its on the dot. so if I was driving 40 with 245 it shows 37-38ish now with the 265 40mph is 40.5 to 41mph ish
  7. Jul 19, 2017 at 2:31 PM
    Clearwater Bill
    Billy
    Largo Florida
    No TPMS work needs to be done.
  8. Jul 19, 2017 at 3:51 PM
    Discount Tire
    Discount Tire Tire & Wheel Specialists Vendor
    Arizona, USA
  9. Jul 20, 2017 at 1:18 AM
    Asdfghjkl123
    california
    Oem
    @tacoshin thanks for the info, did you notice any difference with mpg? would you recommend 265/75/r16 instead 265/70/r16? btw im using stock steel wheels with oem lift
  10. Jul 20, 2017 at 6:23 AM
    tacoshin
    Brian
    @Asdfghjkl123 honestly I didn't see any MPG loss at all. when I was driving with 245 driving 15 miles to work and another 15 back M-F and some weekend driving I usually get 260MPG and after I switched to 265 /75 its still the same. the 265/70r16 is just wider but same size as the 245 in height. so your speedo will be same just maybe .2 or .5 MPH off but the 265/75/r16 is 31.7 wheels so I guess u can consider its 32inch tire so your speedo will be on the dot or .2 or .4ish higher MPH
  11. Jul 20, 2017 at 6:25 AM
    tacoshin
    Brian
    and I do like the 265 75 tires if you can goto wally world online and buy hankooks ATM that's what I got and love them, or falken at3 I got the hankooks all 5 tires for 570 bucks without install
  12. Jul 20, 2017 at 1:17 PM
    Asdfghjkl123
    california
    Oem
    @tacoshin thanks so much for the info very helpful.
    tacoshin likes this.
  13. Jul 20, 2017 at 1:21 PM
    tacoshin
    Brian
    anytime
  14. Jul 20, 2017 at 1:37 PM
    Asdfghjkl123
    california
    Oem
    @tacoshin another question when you did have 245, did you ever scrape the bottom of your truck on a speed bump? i swear everytime i go through a small speed bump for some reason the bottom of my truck scrapes a little even when i don't load much on my truck. Idk if i am heavy or what but i weigh 170lbs
    tgrandstaff38 likes this.
  15. Jul 20, 2017 at 1:39 PM
    tacoshin
    Brian
    huh??? my truck is lifted but before it was lifted I didn't scrape nothing on a bump weird and I weigh 210 at the time. weird
    Asdfghjkl123[OP] likes this.
  16. Jul 26, 2017 at 7:33 AM
    tgrandstaff38
    tgrandstaff38 CCParamedic
    Tyler
    TN
    2015 Tacoma Sr5 4x4
    Wet Okole
    Mine does it everytime i go over a speed bump it gets annoying. One reason i am going to 265
  17. Jul 26, 2017 at 7:49 AM
    tacoshin
    Brian
    Dang when I had the 245 on I never scraped unless your shocks are bottomed out. U guys must have monster speed bumps
  18. Jul 26, 2017 at 8:06 AM
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    Might be scarping on your mud flaps.
  19. Jul 26, 2017 at 10:57 AM
    tacoshin
    Brian
    yeah that could be it scrapping the flaps.
