changing to LED lightings
Discussion in '1st Gen. Tacomas (1995-2004)' started by makikid808, Feb 17, 2012.
  1. Feb 17, 2012 at 12:35 PM
    makikid808
    makikid808 [OP] They call me unko
    Kamaki
    Kula,Maui
    98 Tacoma sr5 4x4 5VZ-FE 3.4 manual
    fabtech 6" lift, all-pro 5" rear lift springs, 17x9 ATX slot, 295/70/17 nitto trail grapplers, Borla catback exhaust system, K&N FIPK, bully nerf bars, wet okole seat covers, tints (factory tint plus 5 on back 35 on front), sounds(kenwood deck, kenwood IE speakers all around,kenwood 720W amp for mids, kenwood 1000W amp pushing orion 12" sub), LED dome map and door lights
    was looking at some led lightings and was gonna get 4 of the bulbs from superbrightleds.com. 2 for the dome light and 2 for the door lights, but i wanted to change the lens of the door light so the cab is brighter. does anyone know where to get lens for the door lights?
  2. Feb 17, 2012 at 6:06 PM
    scotrinaf
    scotrinaf Well-Known Member
    Scott
    Blountville, TN
    04 PreRunner TRD SR5 4x2 2.7L
    Leer 100XQ, Yakima Roof Racks
    You may need to add a resistor for the dome bulb... I tried putting one in mine tonight, it just flickered really fast and was really dim... Search the forum for the fix...
  3. Feb 17, 2012 at 10:35 PM
    makikid808
    Kamaki
    Kula,Maui
    Is that the ones from the super bright LEDs? How about the door lights did you have any luck with those?
  4. Feb 17, 2012 at 10:44 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    You don't need a resistor for interior bulbs. If they're flickering, you may have bad contact or try turning the bulb around and see if that works.
  5. Feb 18, 2012 at 5:05 AM
    scotrinaf
    Scott
    Blountville, TN
    No, the dashboard lights from superbrightleds.com work great, the dome light came from ebay, but the dome light is a different story and does require a resistor, look up the other thread on dome light led bulbs... I haven't changed the door lights yet...
    You'll need 1 - 100 ohm 1 Watt resistor for each map light bulb and 1-2 for the dome light bulb. You can get them for $1.50/ea at Radio Shack.
  6. Feb 18, 2012 at 6:42 AM
    Norton
    Norton Senior Member
    Monument, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C, OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; aFe POWER Magnum FLOW Pro DRY S Air Filter; NSB-AGM27F Battery w/Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Cooper Discoverer A/T3s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; MetalMiller TRD Skid; jsi's Locker Anytime & ramonortiz55's Always on Power Outlet Relay Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades (RallyLights Harnesses, Osram 85/80W H4 & Flösser 90W H11 Bulbs); mattgecko's Underhood Lighting; ND4's Fog Light Anytime Mod; Interior & Reverse LEDs; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; 4Runner 4X4 & FJ Fog Light Switches; Husky Floor Liners; UltraGauge EM; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Toyota Bed Extender; Pop & Lock Power Tailgate Lock; ARE Z-Series Cap, SolarGard Tint; BlendMounted BEL Vector 995; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    This ^^.
    Definitely not true. This is a well-documented 1st Gen problem/feature. See http://www.tacomaworld.com/forum/lighting/154318-48smd-led-dome-lights-4.html#post3229746, http://www.tacomaworld.com/forum/gr...acement-interior-led-kits-14.html#post3360547, http://www.tacomaworld.com/forum/lighting/185091-dome-light-2003-tacoma.html#post3943616, http://www.tacomaworld.com/forum/gr...ment-led-kit-group-buy-5-a-9.html#post3965269, and http://www.tacomaworld.com/forum/1s...dome-light-led-bulb-actually-works-right.html.
  7. Feb 18, 2012 at 3:19 PM
    scotrinaf
    Scott
    Blountville, TN
    I added 2 - 100 ohm 1 Watt resistors to my dome light bulb and each map light bulb and they worked perfectly. Neither would come on with just 1 resistor on them!!!
