Changing to Manual locking hubs??
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rstandridge, Apr 13, 2010.
  1. Apr 13, 2010 at 4:12 AM
    Rstandridge
    Rstandridge [OP] Member
    Rich
    Citrus County
    1999 Tacoma SR5 4x4
    I have heard to many different variations to know what is the truth. I want to be able to get the full lift out of my new Coilovers and cant because I dont have Manual locking hubs! If i purchase the stuff to put in locking hubs will I be able to get the full 3" lift or will 2" be the maximum? Dont want to ruin my cv joints!
  2. Apr 13, 2010 at 7:41 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
  3. Apr 13, 2010 at 9:19 AM
    Rstandridge
    Rich
    Citrus County
    1999 Tacoma SR5 4x4
    I saw this before and I was told that could mke the problem worse because it is not a true 1 inch diff. drop. This is new to me and I dont want to damage my cv joints after like 200 miles or so. Does anyone have the diff. drop on their taco? Thanks alot.
  4. Apr 13, 2010 at 12:10 PM
    Janster
    Jandy
    Lancaster, PA
    Do some more research about the diff drop.
    Converting to manual hubs is far more complex and more expensive. The only thing a manual hub conversion will do for you, is prevent the axle shafts from spinning when they're unlocked. That's it. The shafts will still be at an extreme angle and when you LOCK the hubs - your shafts will be operating at an extreme angle.
  5. Apr 13, 2010 at 2:49 PM
    Rstandridge
    Rich
    Citrus County
    1999 Tacoma SR5 4x4
    Thanks alot, I will see what I can find.
  6. Apr 13, 2010 at 3:10 PM
    99yodataco
    99yodataco Little Taco that could
    Chad
    New Mexico, it's just a little bit fresher.
    99 taco 2.7l SAS
    Dana 44 front and some other useless things.
    I've got both a 3" lift with a diff drop kit and manual hubs on my truck and I do offroad time to time, my cvs are still alive and well. But I got the ddk with my lift.
  7. Apr 13, 2010 at 4:41 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    i got a diff drop on mine, havent wrecked any cv's either.
  8. Apr 14, 2010 at 2:44 PM
    BRP27
    BRP27 When I grow up I want to be just like Me
    So far south in Texas my feet are in salt water
    04 4X4 Tacoma SR5
    3 in Ultimate ToyTec, set @ 2.5 in. AAL PINCH Weld Mod ( beat the pinch weld over inside the fender) Painted the pinch weld on bottom of cab Black Hi Lift Knock off
    Dif drop with the lift
  9. Apr 15, 2010 at 1:02 AM
    dustinuhls
    dustinuhls Well-Known Member
    Manhattan, KS
    '01 Limited DoubleCab 4x4
    3" SL, Nerf Bars, 33" BFGs, K&N, Deckplate, Royal Purple
    I've got the 3" ToyTech coil spacer lift with the 1" diff drop. It's been on for almost 5 years now and my CV boots still look good. No cracks, splits, or tears... I check them regularly b/c I also feared this problem. I'm still running the factory auto hubs...
  10. Apr 15, 2010 at 9:06 AM
    Rstandridge
    Rich
    Citrus County
    1999 Tacoma SR5 4x4
    Sweet! I just got the diff. drop kit and was told also abbout a shim kit. Just for knowlege what exactly is this and how many degrees for a 3'' lift. I already purchased a diff. kit but am now curious about the shim kit?
  11. Apr 15, 2010 at 9:12 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Shim kit goes on the rear axle. If you lift the rear and experience drivelin vibs, then put the shims between the axle and leafs. They should be 3° shims IIRC.
  12. Apr 15, 2010 at 12:32 PM
    Rstandridge
    Rich
    Citrus County
    1999 Tacoma SR5 4x4
    Thanks for the info! Now just a waiting game for the rest of the parts.
  13. Dec 19, 2010 at 7:56 PM
    CdnSldr
    CdnSldr Well-Known Member
    Josh
    Northwestern Ontario (the only good part of ON)
    '96 Sex on Wheels ;)
    Deckplate mod, Bilstein 3" C/O's, NWO 2.5" rear leafs w/ overload, OME greasable Shackles, 33/12.5/15 Dura trac's, 15" Wheelers Steelies Type "B", Sat. Radio, Diff breather mod
    The diff drop kits arent a true 1 inch. Due to the limitation of the steering rack and crossmember being where it is the diff can only really pivot since it is also attached to the crossmember with a bushing on the back side. I does drop it a tiny bit. I have the kit and the toytec ultimate lift (2.5" ish). I just discovered my driver side boot has a small tear and has started puking grease :(
  14. Dec 19, 2010 at 8:05 PM
    desertdude59
    desertdude59 CRAZY 4WHEELER
    From the Mojave desert now in Wild and Wonderful W
    1991 toyota 4x4 sr5-lost but not forgotten
    4" lift after market front bumper bed mount lightbar/roll bar (4)6" kc's on the roll bar (2) kc flat back bumper mounts f/r gears for the 33's
    If you can do hubs then it will prolong the life of the cvs and they wont be spinning at 70 mph when you are on the highway. You'll just have to lock them when wanting 4 wheel drive.
