Changing to Synthetic at 108k miles?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ReidStylez, May 1, 2017.
  1. May 1, 2017 at 7:01 AM
    ReidStylez
    ReidStylez [OP] Well-Known Member
    Reid
    Kansas City
    11 PreRunner SR5
    I am sure this has been beaten to death but I tried searching and didn't really see much on this topic.
    I have 108k on my Tacoma. I've been putting in regular 5-30 Castrol GTX every 3k miles since 27k miles (when I bought it). I was thinking about changing to synthetic but I'm worried about how many miles I have with the change. Mobil 1 has a high mileage synthetic for 75k and higher that I was thinking about using too.
    Is this a bad idea and I should keep doing what I'm doing or are the risks very minimal?
  2. May 1, 2017 at 7:15 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    I do 5-30 dino oil at 5k, never had engine troubles
  3. May 1, 2017 at 7:19 AM
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    You'll be fine. I switched over to a synthetic blend at 120k. It won't cause any harm or "create leaks". The misconception is that synthetic oil causes leaks due to the fact that several years ago they would place a lot of wear on the seals. This has been improved and is a thing of the past. However, IF there are any leaks, synthetic will show them. It is okay to make the switch, but if a leak appears, you may want to switch to a synthetic blend. I hope this helps!
  4. May 1, 2017 at 8:19 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Man up and do it.... stop being a girly girl...
    Just playing.
    You'll be fine with the switch, although you probably should have switched when you bought the truck.
  5. May 1, 2017 at 8:25 AM
    1Shifter
    1Shifter Well-Known Member
    Jeff
    Outta the black and into the blue
    09 PreRunner
    Same as everybody else...
    Made the switch myself, no issues.
  6. May 1, 2017 at 9:03 AM
    80schild
    80schild Well-Known Member
    Chad
    Flori-Bama
    2007 TRD Sport Access Cab
    I believe most synthetics have better cleaning abilities too, so if you have a small leak that has been plugged with sludge, it's *possible* the synthetic will clean it away exposing the leak (very unlikely though).
    It reminds me of the folks that say changing tranny fluid will make it start slipping... well yeah it'll start slipping if the only thing making it work was grit and clutch debris. If that's the case it was close to failing anyways.
    ZachPrerunner[QUOTED] likes this.
  7. May 1, 2017 at 11:01 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    I switched to synthetic at 120,000 miles, no problem at all. Before that I was running conventional at 5,000-mile intervals. Since you've been doing 3000-mile intervals (too short IMO) I have serious doubts about any buildup in your engine, it's probably cleaner than most. Make the switch.
