Changing tranny fluid and filter change
Discussion in '1st Gen. Tacomas (1995-2004)' started by Smokeyslady, Jun 5, 2016.
  1. Jun 5, 2016 at 6:18 PM
    Smokeyslady
    Smokeyslady [OP] Member
    Terry
    Silver 2004 4 Runner SR5 with 225000 original miles
    None
    1. First tranny fluid and filter change since owned, > 225000 miles, tranny running great. But the fluid on my stick has darkened since I bought it a few months ago, oil and filter has been changed twice ( first was changed as part of r/o the engine/ visc light on and the second time was due to the maintenance light, recent engine light code caused me to insert a new catalytic converter!
    2. I placed hi milage oil 5/30wt in per auto parts suggestion
    3. Now I'm asking what the prefered tranny fluid and filter is needed for the upcoming fluid change?
  2. Jun 5, 2016 at 6:32 PM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    There is a screen more so than a filter. If the pan isn't leaking I wouldn't drop it. Draining the pan will yield 4.5qts and I would replace with Toyota type 4. In about a month do it again and good to go.
  3. Jun 5, 2016 at 6:46 PM
    eon_blue
    Azusa, CA
    '04's have a maintenance light? I haven't seen one on mine, though I haven't had it for very long (3 months).
  4. Jun 5, 2016 at 6:47 PM
    Smokeyslady
    Terry
    None
    Okay great , no need to drop the pan to change filter or this screen of a filter, but go ahead drain the fluid now and in thirty days to replace with " Toyota type lV ATF" This makes it good to go for how many miles before I should do again?
  5. Jun 5, 2016 at 6:50 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Do it again in 50,000, less if you do allot of towing.
  6. Jun 5, 2016 at 7:29 PM
    TACO TX
    Kelly
    Denison ,Texas
    Yea, no real time fram on the 2nd drain and fill, couple weeks to a month. You can use whatever fluid you like that is Type 4 compatible I just always used the Toyota fluid.
  7. Jun 5, 2016 at 8:08 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    No, he was talking about the check engine light. There are no maintenance reminders in 1st gens.
  8. Jun 6, 2016 at 2:27 PM
    smirk
    smirk Well-Known Member
    So what you guys are saying is you swap the old transmission fluid with motor oil for a month, drain it, and then fill it back up with transmission fluid? What is the purpose of doing this? I haven't even looked at my transmission fluid since I bought my truck three years ago so I am looking into it soon. Thanks.
  9. Jun 6, 2016 at 3:10 PM
    koditten
    Kirk
    Central Michigan
    No!
    We are talking about 2 different parts of the truck.
    TOYOTA WS transmission fluid for transmission.
    5w30 motor oil for engine.
  10. Jun 6, 2016 at 8:17 PM
    TACO TX
    Kelly
    Denison ,Texas
    1st gen is Type 4 tranny fluid, not WS.
  11. Jun 6, 2016 at 8:27 PM
    2004TacomaSR5
    Jon
    Montana
    I think type 4 was only used in 04 and all years prior were WS.
  12. Jun 6, 2016 at 8:30 PM
    TACO TX
    Kelly
    Denison ,Texas
    Mine was an 03 and the dipstick was marked Type 4. Before Type 4 standard Dexron fluids were the norm
  13. Jun 7, 2016 at 8:21 PM
    Smokeyslady
    Terry
    None
    I went to O'Reillys to pick up the Toyota 4 ATF and told them I needed 5 qrts cause I'm NOT dropping the pan and changing the filter or screen this time, they argued with me that I still required 13 qrtz to change the ATF, at 7$ a wet I told them that is ridiculous! REALLY? I admit this is my first foreign vehicle, but of all the cars,trucks, SUVs, I have owned I never had to use 13 qrtz of anything to change out a fluid, they told me I was thinking motor oil not ATF, AM I CRAZY or did my favorite auto store just go bonkers? That may be capacity amt, but fluid change? Someone correct me if I'm in the wrong?
  14. Jun 8, 2016 at 5:24 AM
    koditten
    Kirk
    Central Michigan
    Sounds like the counter help at the parts store is a little new.
    Just make sure they know you are doing a drain and fill for transmission and not a transmission flush. A flush would need 13 quarts.
  15. Jun 24, 2016 at 6:08 PM
    Smokeyslady
    Terry
    None
    Thank you! I knew I hadn't lost my mind, and you're right they had to be new, but no one else there was helping me out either ! But, anyway I feel much better now and I'm taking my 5 qrts, doing what I gotta do and feeling right about it!
    Thanks man!
  16. Jun 24, 2016 at 6:11 PM
    koditten
    Kirk
    Central Michigan
