Changing wheel bearing
Discussion in '1st Gen. Tacomas (1995-2004)' started by 03TacoWJB, Jul 1, 2014.
  1. Jul 1, 2014 at 9:50 AM
    03TacoWJB
    03TacoWJB [OP] Well-Known Member
    03 Access Cab SR5
    Brought my 4wd 2003 tacoma to the shop today and they said you need a special tool to be able to take the bearing out there is some specialty tool does anybody know the special tool to get the hub off to take the bearing out?
  2. Jul 1, 2014 at 11:58 AM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Front or rear? They both require a special tool front toyota (or a homebrew solution), gotta be more specific.
  3. Jul 1, 2014 at 3:05 PM
    dispatch55126
    dispatch55126 Well-Known Member
    MN
    2004 Xtracab SR5
    Complete OME kit w/ 881's and dakars. All-Pro Sliders, CB, HAM Radio and various other minor stuff.
    Does he sell hub assemblies for Gen1's? I only see listing for Gen2's.
  4. Jul 1, 2014 at 3:13 PM
    muay_thaierd
    muay_thaierd Well-Known Member
    Broomfield
    I just did my front wheel bearing. I didn't have to use any special tools unless a press is considered a special tool. Make note though that before you press the hub from the spindle, don't forget to remove the retaining ring off. I forgot to take it off and the ring got alittle bent out of shape but I was able to bend it back. Other than that it is a simple job to do.
