changing wheel size
Discussion in '2nd Gen. Tacomas (2005-2015)' started by obrien20707, Nov 20, 2014.
  1. Nov 20, 2014 at 6:37 PM
    obrien20707
    obrien20707 [OP] New Member
    Maryland
    2013 Tacoma SR5
    I have a 2013 Tacoma SR5 4 wheel drive with stock 16" wheels. I want to know if I can change to 17" wheels and if so are there any problems with doing so?
  2. Nov 20, 2014 at 6:40 PM
    AndyTaco
    AndyTaco ACLBFTMW
    Andy
    Waco, TX
    '10 ACLB V6
    "Raptor Style" grill mod, aftermarket wheels, 265/75/16 Goodyear Wrangler Authorities, TRD Shoulder pads on seat belts, no mud flaps, AVS Hoodflector bug shield *removed*, Dee Zee Ultrablack Bull Bar w/ license plate mount, dipped my fuel door for no reason, N-Fab Spare tire mount w/ full size matching spare, dipped eyelids onto my headlights for no reason, dipped my hood for no reason
    I've got 265/75/16's and I had to take off my front mud flaps and trim a small bit of plastic to get rid of the rubbing. If you go up from stock to 70/17's it should be about the same situation.
  3. Nov 20, 2014 at 6:45 PM
    smithr1730
    smithr1730 Well-Known Member
    Rob
    Columbus, Ohio
    '15 TX Pro
    Offroad parts and such
    same as above, I have 265/75/16s and I had to remove my front flaps and trim a little plastic. They are about the biggest tires tht your gonna be able to run without lifting..in all honesty, I wouldn't run them unless your planning on getting a lift soon
  4. Nov 20, 2014 at 6:47 PM
    AndyTaco
    AndyTaco ACLBFTMW
    Andy
    Waco, TX
    '10 ACLB V6
    In which case get BIGGER wheels :D
  5. Nov 20, 2014 at 6:49 PM
    Idaholandho
    Idaholandho The other white meat
    3 Now - 2022 Trail Edition, 2015 TRD 4x4 and a 2006 SR5 4x4
    2015 Tacoma, Magnuson Supercharger, Bully Dog Flash and GT, Safari Snorkel, Toytec BOSS 2.5 Coil Over Front, Toytec BOSS Aluma 2.5 Rear, Toytec 10 Leaf Pack, Stainless Brake Lines, Icon UCA's, CBI Reverse Adj Shackle Mounts, CBI Ubolt Flip Kit, Timbren Bump Stops, CBI Bushmaster 2.0 Front Bumper w/ Warn M8000S Winch and SR2 Rigid Flood Lights, CBI Bushmaster 2.0 Rear Swingout Bumper, Rigid SR2 backup lights and Dual RotopaX / Fuel/First Aid Pack, CBI Rock Sliders, CBI Full Skids and CBI Rear Diff Armor, BAMF LCA Skids, FrontRunner Outfitters Slimline II Roof Rack w/ Rigid SR2 40" Combo Light Bar, Rock lights, Rigid pods in Bed Rack, Intelligent Battery System w/ Dual NorthStar batteries, Spod Power Distribution, illuminated switch panel in sunglasses holder, Viar Extreme Duty On-Board Air w/ 2.5 Gallon Tank under bed, Air 2 Air Sys, Magnaflow Exhaust, Fuel Off Road Trophy Wheels, 285/75/17 Toyo Open Country R/T, Diff breather mod, FX-R BHLM Demon Eye headlights, Esuse LED Fog Kit, Pelfreybilt Camera Relocation mount, Pelfreybilt ax/shovel bed mount, Debadged, tint, a 2006 Tacoma SR5 and a 2022 Trail Edition
    Make sure and get the correct back spacing when wheel shopping. Good Luck.
  6. Nov 20, 2014 at 6:49 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Hmm.. My 265/75/16s don't rub at all with my OEM alloys.
  7. Nov 20, 2014 at 6:51 PM
    AndyTaco
    AndyTaco ACLBFTMW
    Andy
    Waco, TX
    '10 ACLB V6
    Really? What year is yours? That's weird, I definitely had to remove mud flaps to even turn, then trimmed the plastic when there was still some rubbing
  8. Nov 20, 2014 at 6:53 PM
    T4RFTMFW
    13 DCSB SR5 Prerunner.
    Not running MTs or anything gnar gnar, but my Dynapro ATMs aren't exactly highway tires.
  9. Nov 20, 2014 at 6:55 PM
    AndyTaco
    AndyTaco ACLBFTMW
    Andy
    Waco, TX
    '10 ACLB V6
    I've got goodyear wrangler authorities. Lots of extra tread, maybe that's it. Rob, what tires are you running?
    Are the 13 wheel wells different?
  10. Nov 20, 2014 at 6:57 PM
    1993t100
    1993t100 I’m good looking and I drive a Jeep.
    Big Sexy
    Nebraska
    Jeep Wrangler Rubicon
    No rubbing on my Bridgestone Revo2's 265/75/16. Stock height. I got rid of the front flaps a long time ago
  11. Nov 20, 2014 at 6:59 PM
    T4RFTMFW
    I'd be surprised if the fender wells are different since they didn't change much elsewhere.
  12. Nov 20, 2014 at 7:01 PM
    AndyTaco
    AndyTaco ACLBFTMW
    Andy
    Waco, TX
    '10 ACLB V6
    Yeah. Interesting, though.
  13. Nov 20, 2014 at 7:05 PM
    T4RFTMFW
    Those Authority's are meaty. Mine are P metric, not LT, so that could be something also.
  14. Nov 20, 2014 at 7:14 PM
    AndyTaco
    AndyTaco ACLBFTMW
    Andy
    Waco, TX
    '10 ACLB V6
    Yeah, they are. Sounds about right. My brain is unrattled now, thanks! :p
  15. Nov 20, 2014 at 7:40 PM
    smithr1730
    Rob
    Columbus, Ohio
    '15 TX Pro
    I'm running Cooper A/T3s...so not too meaty but still have a more aggressive tread
  16. Nov 20, 2014 at 7:42 PM
    AndyTaco
    AndyTaco ACLBFTMW
    Andy
    Waco, TX
    '10 ACLB V6
    It's probably a mixture of both general meatiness & aggressive tread then.
  17. Nov 20, 2014 at 7:48 PM
    smithr1730
    Rob
    Columbus, Ohio
    '15 TX Pro
    yea, I mean it kinda makes sense. I'm hoping to get my Billie lift for Christmas this year and finally clear the tire rub :D
  18. Nov 21, 2014 at 5:26 AM
    karmatp
    karmatp Well-Known Member
    Trevor
    Chandler, AZ
    2016 4x4 4Runner
    I went from 256/70 to 265/75 and I have lots of space on my '14. I did have aftermarket rims on my truck for about a week and I was so close to rubbing, I probably would have off road.
    Once I went back to the OEM rims, I had lots of space again and never rub, even with hard wheeling. People get into trouble with aftermarket rims, the offset can make you rub.
