Changing wheel studs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JeffBoyardee, May 13, 2020.
  1. May 14, 2020 at 2:46 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I've always knocked them out with a hammer and pulled them in with a lug nut. Easy as pie.
    Biscuits, kbp810 and Muddinfun like this.
  2. May 14, 2020 at 3:34 AM
    JeffBoyardee
    JeffBoyardee [OP] Well-Known Member
    Jeff
    Seminole, FL
    2011 TRD Off-Road Tacoma DCSB
    That's what I've done in the past, and it's probably fine, but you're really not supposed to introduce that kind of stress to the stud's threads. The "correct" way is to press them. Using the ball joint separator is pressing them, and takes a whole lot less bicep.
  3. May 14, 2020 at 3:35 AM
    JeffBoyardee
    Jeff
    Seminole, FL
    I have not. Before doing this I always pulled them in with a lugnut. I just liked that this wasn't pulling all those forces on the thread.
  4. May 14, 2020 at 8:47 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    A little grease on the knurled portion, and they pull in with less torque than what is required to torque the wheel down. As long a a high grade washer and nut are used, there will be less induced elastic stretch on the studs, than normal torquing specs.
    Biscuits, Jimmyh and Muddinfun like this.
  5. May 14, 2020 at 8:50 AM
    JeffBoyardee
    Jeff
    Seminole, FL
    Cool. Just sharing a method I found easier.
    Brie and Torspd[QUOTED] like this.
  6. May 14, 2020 at 8:58 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    That is what we are here for. To all share.
    Brie likes this.
  7. May 14, 2020 at 7:25 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    I introduce more stress than that when tightening the wheel onto the truck.
    If you align the splines properly between the stud and the axle it goes right in with hardly any strain at all. I'm talking about using a 1/2 inch ratchet handle and one hand.
  8. May 14, 2020 at 7:36 PM
    JeffBoyardee
    Jeff
    Seminole, FL
    The hubs aren't "splined". It's just a hole. And the stud is knurled to make a light press fit. Don't use the ball joint separator. To me, it's easier, and it makes me feel like the job is done a little more properly. I was just trying to drop a helpful note about the tool.
    Jimmyh[QUOTED] likes this.
  9. May 15, 2020 at 5:08 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I was wrong when I used the word knurled. I had a brainfart and couldn't think of splined.
    Biscuits and Jimmyh like this.
  10. May 15, 2020 at 5:31 AM
    JeffBoyardee
    Jeff
    Seminole, FL
    But it is just knurled. You used the right word.
  11. May 15, 2020 at 7:29 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  12. May 15, 2020 at 7:34 AM
    JeffBoyardee
    Jeff
    Seminole, FL
    Torspd[QUOTED] likes this.
  13. May 15, 2020 at 7:44 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Well good. Past me was still accurate. Lol
    JeffBoyardee[OP] likes this.
  14. Oct 5, 2020 at 5:55 PM
    Vehement
    Vehement Active Member
    Colorado
    I broke a couple of and decided to replace every one. Of course I forgot to put it into 4WD for the front. Am using an air impact + 5/8 nut + lug nut to reseat them, but I'm afraid all that torque is going to fuck up the new studs. Its a LOT of torque and they've been needing a lot of hammering to seat fully.
  15. Oct 5, 2020 at 6:59 PM
    #35
    Vehement
    Colorado
    So you got the studs fully seated with that tool???
  16. Oct 6, 2020 at 7:53 AM
    #36
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Spray some lube, or put some antiseize or grease on them. Helps tremendously, when a press isn't an option.
  17. Oct 6, 2020 at 8:25 AM
    #37
    Vehement
    Colorado
    Isn't lube/grease not a good idea on press fits?
  18. Oct 6, 2020 at 8:30 AM
    #38
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    Nice. And I thought I was a rockstar with my nut and washer bearing.
  19. Oct 6, 2020 at 8:34 AM
    #39
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Stretch the threads, or seat the studs? That depends on how much and interference there is. They are knurled and interference, so they won't spin in seat. Lug nuts hold them in. So it'll be fine in this case.
  20. Oct 6, 2020 at 8:46 AM
    #40
    Vehement
    Colorado
    Well... I'm worried about stretching/damaging the threads when seating the studs. Judging by the amount of hammering needed to seat one, It does seem like there is plenty of interference.
    Well, how about this: After seating one, there is a minor but noticeable increase in slop between the lug and the stud compared to new, un-touched studs.
