CHanging "WS" AutoTrans Fluid in 2006
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SpecialED, Sep 9, 2009.
  1. Sep 9, 2009 at 3:33 PM
    SpecialED
    SpecialED [OP] Active Member
    Ed
    Southtern MD (Chuck County)
    06' Tacoma Double Cab
    N/A
    I know that many people say that this should be left to the dealer, but has anyone here done this with success? I have a 2006 Tacoma V6 with Auto Tranny that uses the WS fluid and would like to change it since it just turned 50,000. Any suggestions with be apreciated!
    Thanks!
    Ed:cool:
  2. Sep 9, 2009 at 3:47 PM
    johnecon2001
    johnecon2001 Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
    It's said you don't need to even think about it until 100,000 miles. What indications do you have that it needs to be changed now?
  3. Sep 15, 2009 at 5:31 PM
    MatteTaco
    MatteTaco Member
    Jon
    Orlando
    I work as a tech for toyota...we dont touch WS till around 100k. If you want to thats up to you. we have a special machine we put fluid into and it flushes and refills the trans with WS. Its up to you but i can assure you your not going to do any harm to your trans by waiting till 100k to change it.
  4. Nov 21, 2012 at 7:38 AM
    jiggee11
    jiggee11 Member
    nj
    06 basic 4x4
    hi, i feel like the engine is straining and i hear a winding sound, i'm thinking it could be the front diff. or auto trans 06' tacoma but they say the tranny should be good till 100k so what could it be never felt it or hear this noise b4.
  5. Nov 21, 2012 at 7:44 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    I'm hoping you've been changing the fluid in the front end, rear end and x-fer case regularly. Assuming you have, check the fluid level in the transmission. Too much or slightly low fluid levels can make the transmission act up (there is a process for checking the transmission fluid level, not just a simple fill plug check).
  6. Nov 21, 2012 at 7:56 AM
    jiggee11
    jiggee11 Member
    nj
    06 basic 4x4
  7. Nov 21, 2012 at 8:16 AM
    jiggee11
    jiggee11 Member
    nj
    06 basic 4x4
    no 65,000 miles only changed oil every 3,000 miles
  8. Nov 21, 2012 at 8:19 AM
    Pugga
    Massachusetts
    F-150 Mod
    How frequently have you been changing the oil in your differentials and x-fer case or have you ever changed them?
  9. Nov 21, 2012 at 8:21 AM
    jiggee11
    jiggee11 Member
    nj
    06 basic 4x4
    never changed any other fluids other then engine oil every 3,000 miles
  10. Nov 21, 2012 at 8:41 AM
    Pugga
    Massachusetts
    F-150 Mod
    Now might be a good time to change that :D
    Change your fluids and check the fluid level in the transmission. The fluid change alone might solve the problem.
    Ever changed the spark plugs? Not related, but something that is frequently forgotten.
  11. Nov 21, 2012 at 8:53 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR
    back to bone stock.
    my independent toyota shop flushed mine for $200. i had 70k miles on it..alot of it towing a trailer about.
