Charcoal canister delete
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WittBro, Sep 14, 2016.
  1. Sep 14, 2016 at 11:01 PM
    WittBro
    WittBro [OP] New Member
    06 Tacoma
    Flatbed, auxiliary fuel tank, 3" lift
    Anyone successful with removing the charcoal canister? Mine got filled with fuel and I would like to just delete the whole thing.
  2. Sep 15, 2016 at 4:38 AM
    98tacoma27
    Ben
    Not Beech Creek
    Welcome to TW.
    I haven't seen or found any one that has done this on a Tacoma. It would require resistors if you're concerned about the CEL being on constantly.
  3. Sep 15, 2016 at 4:41 AM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Need to put this in the Top Off Fuel Tank thread.
    don't max out the filler neck, then goes right to the charcoal canister.
  4. Sep 15, 2016 at 4:42 AM
    WittBro
    06 Tacoma
    I'm not worried about cel's, just wanna get rid of the evap system so my truck will run. I have read several threads on the 3.4 but see nothing for a 4.0.
  5. Sep 15, 2016 at 4:47 AM
    WittBro
    06 Tacoma
    Bought the truck totaled rebuilt it over the last couple years, auxiliary fuel tank in the bed plumbed into the stock tank, got the plumbing figured out but not before the charcoal canister got fuel in it a couple times. Still ran fine after draining the fuel for bout 10,000 miles then started cutting out and stalling. Don't care about cel's just wanna delete the system. Any help would be great , thanks.
  6. Sep 15, 2016 at 4:53 AM
    Gearheadesw
    Davenport Fl
    Are you able to simply drain it? Has it ruins media on the inside? Yank it out and plug the hoses, not good for emission control. See what happens...
  7. Sep 15, 2016 at 4:56 AM
    WittBro
    06 Tacoma
    Tried that, motor dies when you give it throttle.
    Gearheadesw likes this.
  8. Dec 1, 2022 at 10:04 AM
    FishaRnekEd
    FishaRnekEd Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
  9. Dec 1, 2022 at 10:05 AM
    FishaRnekEd
    New Orleans, LA
