Charcoal canister replaced!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by xTACOMAx, Mar 6, 2014.
  1. Mar 6, 2014 at 4:50 PM
    xTACOMAx
    xTACOMAx [OP] Well-Known Member
    07 prerunner TSS
    Rough Country 3 inch lift, Aries bull bar, Spider headlights
    This passed week my truck has been at the Toyota dealership having the charcoal canister replaced, as far as I know of the charcoal canister is located around or on the gas tank (correct me if I'm wrong) well in the passed my gas gauge has been messing up not showing the accurate amount of gas (can go in better detail in how the gauge is acting) but could that be the reason my gas gauge was acting up and causing inaccurate readings? Thanks!
  2. Mar 6, 2014 at 6:51 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    short answer..
    NO.
    Charchol canister simply grabs the gas fumes from the tank and stores them to be burnt by the motor, thats all it does.
  3. Mar 6, 2014 at 6:53 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Charcoal canister is in the filler stem not the tank
  4. Mar 6, 2014 at 7:54 PM
    car78412
    car78412 Well-Known Member
    Hudson Valley NY
    13 Tacoma reg cab 4x4
    Which is why you should never overfill your gas tank. This will destroy your carbon canister which is very expensive to replace.
  5. Mar 6, 2014 at 9:55 PM
    xTACOMAx
    07 prerunner TSS
    Ok thanks guys, I didn't know really what it did and thought I would ask to see if that might have been the problem with my gas gauge cause Toyota said they can't fix my gas gauge for stupid reason.
  6. Mar 6, 2014 at 9:58 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Canister is mounted behind the tank.
    The vent to the canister is in the fill pipe.
