Charcoal cannister
Discussion in '1st Gen. Tacomas (1995-2004)' started by jalers, Mar 4, 2009.
  1. Mar 4, 2009 at 5:36 PM
    jalers
    jalers [OP] Member
    Panama City, FL
    03 Prerunner SR5
    side step
    I got a 2003 Taco 4dr prerunner, with the annoying check engine light on. Finally took it to Toyota and after changing gas cap again, they say it is a bad charcoal cannister. Don't want to pay what they want for it and I'm an average do it yourselfer. Can't find it in junkyards, so leaves me asking you guys if you have or know of a junked taco with one that I can buy? Thanks
  2. Mar 4, 2009 at 7:10 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    check out www.rockauto.com
    They have something called a vapor canister, I don't know if that's the same thing though. They have a picture of it on there, so if it looks the same I'm guessing it's the same part.
  3. Mar 4, 2009 at 9:58 PM
    jalers
    jalers [OP] Member
    Panama City, FL
    03 Prerunner SR5
    side step
    Yes, I guess it is the same part, but $319 that is what the dealer is asking for theres. Just let me know if anybody knows where I can get one. Thanks. Still looking.
  4. Mar 4, 2009 at 10:55 PM
    AUDITECH
    AUDITECH Carolina Alliance: LAZY DIVISION
    charlotte nc
    07 double cab prerunner
    none
    try advance auto pep boys places like that but the cannister is a rare item. do you fill your tace to the fullest everytime you fill up with gas
  5. Mar 5, 2009 at 1:24 PM
    jalers
    jalers [OP] Member
    Panama City, FL
    03 Prerunner SR5
    side step
    I tried them and they all say its a dealer item. I always fill it up ontill it stops, why?
  6. Mar 5, 2009 at 1:27 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    Mine was broken as well, crack in the bottom. Honestly, it doesnt affect daily driving or performance if the CEL is on. I broke down and bought the part and installed it myself, took 3 min. The dealer wanted $80 for labor to install it, I said hell no.
  7. Mar 5, 2009 at 1:58 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    yea what does it do? Recycles gas fumes or something?
  8. Mar 5, 2009 at 2:20 PM
    itsmyturn
    itsmyturn Well-Known Member
    Victorville, CA
    08 dbl cab TRD sport
    afe Pro-Dry S dropin, Readylift leveling kit, TRD skid plate, Alpine CDA-9887, 6K D2S HID
    check your owner's manual for emissions warranty. here in cali any emissions part is covered 8/80 or 10/100(years/mileage). some parts even have up to 15/150k from the factory. but it depends state by state.
  9. Mar 5, 2009 at 2:45 PM
    jasonh
    jasonh tossed salad anyone?
    Dallas, TX.
    2007 Pre Runner SR5
    Billy 5100's
  10. Mar 5, 2009 at 2:46 PM
    bobwilson1977
    bobwilson1977 Well-Known Member
    KaliFORN-I-A
    96 Tacoma 2WD ( pizza delivery model)
    none except for crappy hub caps and floor mats.
    I think it's supposed to remove contaminants and moisture from crankcase gasses, so its actually a pretty important item. Without it your engine will start to sludge.
  11. Mar 5, 2009 at 7:23 PM
    dually
    dually Low and slow
    Crankcase vents are routed to the intake manifold. The charcoal canister is for vacuum and emissions.
  12. Mar 5, 2009 at 7:39 PM
    HerNameIsLucy
    HerNameIsLucy I miss Lucy. :-(
    Equador. Don't know why.
    RIP Lucy.
    She's gone but not forgotten.
    the charcoal canister is for storage of fuel vapors until the ecu senses a running condition that is optimal for feeding them back to the engine.
    Pulled this from the TN forums:
    My check engine light came on once, also... It turned out that I had filled my tank, and then topped it off a bit more, and then drove it 2 blocks and parked it for a week while I went on vacation..
    The gas expanded and filled my charcoal canister.
    I had the check engine light reset by Autozone (free) and have never had the problem again..
    The cure?? When the handle on the pump goes click, put the handle back on the gas pump.. I haven't attempted to over fill and I haven't had a problem since.
    __________________
  13. Dec 15, 2011 at 4:37 PM
    PJDOGM
    PJDOGM New Member
    New York
    04 SR5 TRD
    155,000 miles on my 04 Taco. The check engine light came on and the code pointed to the charcoal cannister. I followed the advice on this post let the gas tank run down, reset the check engine light and haven't filled the tank in several hundred miles and the light is still off. The truck runs normal, gas mileage is the same. Passed the NYS emissions inspection today. Thanks for the advice.
  14. Apr 22, 2014 at 6:31 PM
    WFD
    WFD Well-Known Member
    Springdale, Utah
    '96 3.4L 4x4 5 Speed Man
    OME Suspension 2" lift, Leer high-rise topper w/ sleeping platform.
    OOh, this is inspiring. A friend of mine recently borrowed my truck, and (nicely) filled the tank up upon return. We went out doing some light 4 wheeling that evening and during the drive the CEL came on (p0446). I haven't messed with anything yet, just been reading the TW forums on this.
    Called my friend and he said that he did in fact top off the tank that day. I will clear the code and see what happens.
    Does anyone know of a way to 'blow out' or clear out the canister if the code come back on after clearing? Trying to avoid buying a new canister. Visually inspected the hoses and connections and they look good BTW.
  15. Apr 22, 2014 at 6:49 PM
    Archer550
    Archer550 Well-Known Member
    Winnipeg
    04 xtracab TRD MT
    ARB for now
    car-part.com sometimes can return good parts from nearby wreckers
  16. Apr 22, 2014 at 7:03 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    You need to fix that. When the charcoal canister is bad, the check engine light comes on and puts your truck into "open loop" mode. You are sending in burnt fuel into your cat and loading it up. The cat will eventually fail. Catalytic filters are very expensive on our trucks. $900 expensive. after market cats won't cut it for very long.
    Ask me how I know:(
  17. Apr 22, 2014 at 7:33 PM
    dispatch55126
    dispatch55126 Well-Known Member
    MN
    2004 Xtracab SR5
    Complete OME kit w/ 881's and dakars. All-Pro Sliders, CB, HAM Radio and various other minor stuff.
    This is good to know. I was wondering what that box above the fuel tank was. Obvious question though is does it need this AND 2 cats.
