Charging Back-of House Power Stations: DC-DC Converter versus DC-AC-DC Inverter
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Truckee, Oct 17, 2024.
  1. Oct 17, 2024 at 3:13 PM
    Truckee
    Truckee [OP] Member
    Hello,
    Looking into wanting to charge up my EcoFlow Delta 2 faster than my 12V cigarette lighter can output (which is a max of 100W/h). After some research I found you can install a DC to DC converter that will feed off the house battery/alternator and charge at 400W/h. But then I also came across some threads where people were questioning the complexity and cost of installing a DC to DC Converter when you can do the same thing with a DC-AC-DC Inverter for much less, and with the added benefit of having AC available for any other needs should the EcoFlow be drained. One poster on a separate forum noted down the Pros and Cons as such:
    DC-DC
    Pros:
    can run in tandem with shore
    more efficient
    no ac selector switch needed
    Cons:
    Lower Power Output
    Cost more
    Larger Wires
    Standalone setup
    DC > AC > DC
    Pros:
    cheaper
    smaller wire
    charge rate controlled by victron
    backup AC inverter
    Cons:
    less efficient
    can't run in tandem with shore.
    Although to the last point, I did learn that with Victron units you can run a DC>AC>DC system in tandem with shore power.
    Trying to decide what makes sense here. Thanks in advance to many of you who understand this stuff waaaaaay better than I do
  2. Oct 17, 2024 at 3:30 PM
    Shellshock
    Iowa
  3. Oct 17, 2024 at 3:35 PM
    545 Well-Known Member
    2015 Access Cab
  4. Oct 17, 2024 at 3:52 PM
    Truckee
    Truckee [OP] Member
    Yes, thank you, I did see that EcoFlow has their own version of a DC to DC converter. It is very expensive for what other brands can do much more cheaply. Regardless, it IS a DC to DC converter and I’m curious to know if an AC>DC>AC inverter is a better option, and if not, why?
