Charging issue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dianna, Feb 28, 2016.
  1. Feb 28, 2016 at 7:08 PM
    Dianna
    Dianna [OP] Well-Known Member
    Dianna
    Ohio
    -06 Tacoma Sport -77 FJ40 -14 4Runner Trail Premium -19 Tacoma TRD Sport Cement Gray
    I got my truck back from a fresh frame swap, the battery and alternator were also both replaced. After having the truck back for a few days, I went to start it and nothing, starter would not even turn over. I charged the battery up for about 20 minutes, and left for work, assuming the 20 minute drive would finish charging the battery. When I left work, the battery was pretty low, but I was able to get it started.
    No issues for a couple more days, and now the battery will not hold a charge. I put my charger on it (a newer Craftsman digital read) and I charge it to 100%, disconnect and reconnect charger, and it reads around 68%. I repeated this over the course of a few hours today.
    What's going on? Bad battery? Bad alternator?
  2. Feb 28, 2016 at 7:12 PM
    Blacktaco2042
    Blacktaco2042 Well-Known Member
    wisconsin
    supercharger/trd cat back 3inch lift 265/75/16 duratracs bumper guard led bar
    the battery most likely has a bad cell, take it back and get it replaced for free. should have a warranty on it
    digitaLbraVo and Dianna[OP] like this.
  3. Feb 28, 2016 at 7:18 PM
    Dianna
    Dianna
    Ohio
    Thank you. I wish the Toyota battery for sale at the dealership was the same battery that you could purchase from the parts department. My first battery lasted 6 years, this is my third battery since 2012. :(
  4. Feb 28, 2016 at 7:18 PM
    Blacktaco2042
    wisconsin
    should all be the same.
  5. Feb 28, 2016 at 7:20 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Could be a bad ground too.
    McTeague likes this.
  6. Feb 28, 2016 at 7:35 PM
    Dianna
    Dianna
    Ohio
    When I charged it up the first time, it started right up. I turned it off and tried to start it again immediately, and click...
  7. Feb 29, 2016 at 3:30 AM
    Dianna
    Dianna
    Ohio
    Right, they should be, but unfortunately they are not. OE is Panasonic, Truestart is junk.
  8. Feb 29, 2016 at 3:38 AM
    Blacktaco2042
    wisconsin
    truestart is made by interstate.
  9. Feb 29, 2016 at 5:27 AM
    Dianna
    Dianna
    Ohio
    Are you sure about that? Where are you getting that information? As far as I know, from reading this forum, Truestart batteries were once made by Interstate and are now made by Johnson Controls.
  10. Feb 29, 2016 at 5:35 AM
    Blacktaco2042
    wisconsin
    Interstate drops them off at my dealer and that what the parts manager told me.
  11. Feb 29, 2016 at 5:49 AM
    Dianna
    Dianna
    Ohio
    I wonder if that's the case with all Toyota dealerships, or if different areas have different suppliers. I am ready to just buy another diehard platinum. I had one in my FJ40 that lasted 12 years. I abused that battery too, my FJ40 sits in the winter, I sometimes forget to turn on my trickle charger, that battery has been completely flat at least 10 times. I also use a winch, it never flinched.
  12. Feb 29, 2016 at 5:58 AM
    McTeague
    McTeague Well-Known Member
    Alan
    2012 MGM Tacoma DCSB TRD Off Road
    Stock
    Because it happened after frame swap my guess is bad ground.
    Dianna[OP] and shakerhood like this.
  13. Feb 29, 2016 at 8:23 AM
    Pigpen
    Dan
    Northwest Montana
    This. Maybe just a loose ground.
    Dianna[OP] likes this.
  14. Feb 29, 2016 at 11:02 AM
    Dianna
    Dianna
    Ohio
    I'm taking the truck in tonight, I'll update on the issue. If it was a bad ground, it doesn't make sense to me that my battery charger would reach 100% and then upon disconnecting, and reconnecting, it would always read about 68%. That's what makes me believe that the battery is to blame.
  15. Feb 29, 2016 at 12:14 PM
    Pigpen
    Dan
    Northwest Montana
    If the ground is loose and you jostle it just right, the truck will run (or charge) fine until the ground moves enough to not do its job. I have experienced this with my Tacoma. I had disconnected the battery and not retightened the ground. it coud be at the battery, or at the main ground(s).
  16. Feb 29, 2016 at 12:24 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    sounds like a bad cell to me as well...a load test at Autozone or other parts store can check your battery out. Sometimes its the alternator not charging which takes out the battery.
  17. Feb 29, 2016 at 3:03 PM
    Dianna
    Dianna
    Ohio
    I have a load tester, the battery tested good, can a battery pass a load test with a bad cell? Truck is at the dealership now...
  18. Feb 29, 2016 at 3:57 PM
    shakerhood
    Southern Ohio
    I still say there is a bad ground, its too much of a coincidence that this happened after a frame swap.
  19. Feb 29, 2016 at 6:47 PM
    shakerhood
    Southern Ohio
    Keep us updated on what they find.
  20. Feb 29, 2016 at 7:06 PM
    Dianna
    Dianna
    Ohio
    I'm in a rental, they are also fixing a bad door scratch that I received as a result of the frame swap. I will update as soon as I find out!
