Charging issues?
Discussion in '1st Gen. Tacomas (1995-2004)' started by AEDC, Dec 26, 2010.
  1. Dec 26, 2010 at 6:28 PM
    AEDC
    AEDC [OP] Member
    CA
    Tucoma
    Hello,
    I have a few questions on the charging system on the 2002 Tucoma.
    The charging system is not keeping the battery charged. Now thats usually an obvious thing however after getting a new alternator installed I have the same issues back within 3 days. The battery has been changed as well through this process.
    I was also wondering if changing the headlights to a higher wattage would have added to this issue?
    What is the stock output on this vehicle?
    And is the regulator integtrated into the alternator or is there any external componet that regulates this elsewhere..
    Or did I just actually get a bum replacement.
    Any help would be great. Dont have access to any manuals etc as were out for the holiday weekend.
  2. Dec 26, 2010 at 6:57 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    The voltage regulator is integrated into the alternator. Measure the voltage at the battery with the truck running. It should be 13.7 VDC or higher. I think the stock alt puts out 90AMPS but I am not 100% sure on that. You can also have the system load tested.
  3. Dec 26, 2010 at 7:15 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    If you changed out the alternator and the battery I would check your battery cables. If everything looks good I would look for something that is draining the battery.
    Did you have the battery or alternator tested before you changed them or are you just throwing parts at it and hoping to correct the issue?
  4. Dec 26, 2010 at 7:56 PM
    AEDC
    AEDC [OP] Member
    CA
    Tucoma
    well heres the irony,, Im an experianced mechanic. And belive me when I say I went for all the obvious things. Cables are good, wires check out. Even tagged the yellow wire and didnt get a change other than alt light turning off. System runs at proper voltage until the load hits it. Dies slowly. What boggles me is it was tested and said to ok. Got a new alt. Minutes later same prob. It was a re-man...
    Its my buddies truck. Were kinda displaced so I figured the net would be best to figure this out.
    So basically Im starting to belive its just not enough amps. He started to have these probs after installing a new set of "high power" headlight bulbs. My test drive show no issues with the lights off.
    Im thinking the new load overworks the regulator. The lights I believe are about 200watts which would make for about 16 amps roughly. Most alternators are rated for about 75% capacity.
    Does this sound familiar to anyone?
    Anyone recommend a better alternator?
  5. Dec 26, 2010 at 8:17 PM
    dexterdog
    Oly WA
    2012 F150
    People run high wattage amps with little issue. I would look for a current draw coming from something but first I would put the stock bulbs back in.
  6. Dec 26, 2010 at 10:09 PM
    AEDC
    AEDC [OP] Member
    CA
    Tucoma
    Well, that would leave the last option as hes left those at home. Im fairly certain he just got a de-bunk reman on the replacement.
    So to be certain theres no body control modules etc that interupt the charge circuit?
    It does stall when the bat is disconnected...
    The three wires? Yellow I belive is the charge signal?
    Anyone know the pin-out on them? Thanks? Then I think Im good thanks.
  7. Dec 26, 2010 at 10:15 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Its pretty conclusive if it wont stay running when the battery is disconnected...
  8. Dec 27, 2010 at 12:22 AM
    AEDC
    AEDC [OP] Member
    CA
    Tucoma
    Agreed... Thanks everyone and Ill be sure to post the outcome.
  9. Dec 27, 2010 at 12:33 AM
    AEDC
    AEDC [OP] Member
    CA
    Tucoma
    Oh yeah almost forgot , anyone know the pin-out for the colored wires on the hardshell that plugs into the back of the alternator? The small , (yellow, red , white) wires?
    Thanks.
  10. Dec 27, 2010 at 4:54 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
  11. Oct 8, 2011 at 6:37 PM
    CdnSldr
    CdnSldr Well-Known Member
    Josh
    Northwestern Ontario (the only good part of ON)
    '96 Sex on Wheels ;)
    Deckplate mod, Bilstein 3" C/O's, NWO 2.5" rear leafs w/ overload, OME greasable Shackles, 33/12.5/15 Dura trac's, 15" Wheelers Steelies Type "B", Sat. Radio, Diff breather mod
    Can anyone confirm if this is the same for a 96 3.4? It appears to be the same, 3 pin (red, yellow, white) harness, however my 96 has an 80amp fuse, not the 120 thats shown for the 2003.
    Im having a very similar issue. Been thru 2 different alternators already...really hoping I got another bad one.
  12. Oct 9, 2011 at 7:40 PM
    shanetaco
    shanetaco New Member
    shane
    georgia
    00 tacoma sr5 4x4 v6 trd
    too many to list
    first i would check the grounds (battery to chassie, chassie to engine block, then battery to body) and make sure they were all sanded clean and tight.
  13. Oct 10, 2011 at 5:37 PM
    CdnSldr
    Josh
    Ive checked everything, I even ran a separate jumper wire from the alt housing to the negative terminal just to be safe.
    Ive done continuity tests at every connection that I could find.
    What I need to know is which wire supply's the "signal" to the alt? According to the above diagram it is the the white wire via the 7.5amp fuse. I jumped 12v right to the white pin (middle) on the alt and still no output.
    Another thing is: My DRL's are not working. Which leads me to believe that no power is coming from the yellow wire (as per diagram). My truck doesnt have the low voltage light either (or the bulb is burnt out)
    The blower motor is not working either. It quit the same time the alt crapped out, so I dont think the motor is bad.
    I cant get the alt tested for a few more days so I will be waiting for any helpful responses!
    Thanks TW!
  14. Oct 11, 2011 at 7:36 PM
    CdnSldr
    Josh
    Bumpidy bump....anybody??
