Charging Light Issues, HELP
Discussion in 'Technical Chat' started by Doublee, May 4, 2013.
  1. Jun 20, 2013 at 5:46 PM
    Ryanv
    Ryanv Toyota Technician
    15 4Runner
    Electrical tape over the light
  2. Jun 21, 2013 at 12:17 PM
    Doublee
    Doublee [OP] Well-Known Member
    Tennessee
    06 Access Cab 4WD TRD
    I am about to that point but having issues with DTRL. Some times they work and some times not. I have replaced Alt, belt fuses cleaned all grounds that I can find. Battery checks good and cables are clean and tight. I even replaced DTRL relay and harness. Getting over 13.8 amps running with lights and air cond. on. STILL have charging light on.............
  3. Jun 21, 2013 at 1:40 PM
    rhavin42
    rhavin42 Well-Known Member
    Vladimir
    Phoenix, AZ
    09 DC LB SPORT 4x4
    Dont know if this will help you or not but here is the charging circuit diagrams.
  4. Jun 21, 2013 at 1:49 PM
    rhavin42
    Vladimir
    Phoenix, AZ
    09 DC LB SPORT 4x4
    And the troubleshooting section of the 05 FSM
  5. Jun 21, 2013 at 7:50 PM
    Doublee
    Tennessee
    This will be a great help, Thanks check back in and I will update post when I get this thing whipped.
  6. Jun 22, 2013 at 7:04 PM
    Shadetree
    Shadetree Well-Known Member
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Locking Tailgate & Gas Cap and extra bed D-rings
    A charging indicator will turn off when there is an open on either side of the indicator or when both sides are the about the same voltage. If the indicator on, there is voltage on one side on the indicator and a ground or lower voltage on the other side. It is this voltage difference that causes current to flow and illuminate the indicator.
    If you can monitor both sides of the indicator, that will help you find out what is creating the fault--voltage or ground from charging system or battery. It is most probably something that is common to both the DTRL and the charging indicator like a short to ground.
  7. Jun 23, 2013 at 1:43 PM
    Doublee
    Tennessee
    The only thing I have not checked are connections from neg. cable to inside of fuse box. I have worked for a couple hours trying to remove top panel to get to underside (inside) of box. I can remove entire box from truck but cannot dismantle top.
  8. Nov 14, 2013 at 4:45 PM
    Doublee
    Tennessee
    FIXED !!!! Back to dealer today ( Diff. dealer) 5 hours later fixed 250.00. Found broken wire between Alt. and fuse box. Thanks for all the input. Still cant believe 95.00 dollar diagnostic fee covered two hours of looking. Very fair dealer.
