Charging Phone , laptop, etc
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Boco10, Oct 15, 2020.
  1. Oct 15, 2020 at 9:13 AM
    Boco10
    Boco10 [OP] Well-Known Member
    ADK
    My phone and other electronics charge but very slowly. I am heading across country in two weeks. Any suggestions? I don't really have a lot of time due to work. That and I have new Spyder headlights, OEM Fogs and new topper yet to install. It will be a busy weekend.
    six5crèéd likes this.
  2. Oct 15, 2020 at 9:15 AM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    Stay off of them while driving :thumbsup:
    MattCowsmasher likes this.
  3. Oct 15, 2020 at 9:19 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    Get a jump pack, good to have anyway Incase your battery needs a jump.
    I have a gooloo with charging ports for phone
  4. Oct 15, 2020 at 9:19 AM
    GSPdog7
    GSPdog7 Well-Known Member
    Allen
    Central VA
    2015 Silver Sky Metallic TRD Off-road
    Buy a small inverter. That’s what I did when charging anything with a 110 plug or want more than the slow usb plug they give you. Works good.
    0xDEADBEEF likes this.
  5. Oct 15, 2020 at 9:23 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    If the laptop has a 12v adapter use that. If not, get an inverter. I've had the same 200w inverter for about a decade now.
  6. Oct 15, 2020 at 9:29 AM
    Bodyguard89
    Bodyguard89 Well-Known Member
    Montana
    2010 TRD OR DCSB
    Still in planning phase ...
    I just use USB 12v plug in and USB cable and keep things plugged in and mounted on cradle on RAM mount. And inverter for anything else that needs more juice.
  7. Oct 15, 2020 at 9:58 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    question is where are you trying to charge from?
    Plain Jane Taco and Bodyguard89 like this.
  8. Oct 15, 2020 at 10:00 AM
    Boco10
    ADK
    Usb and both cigarette ports. I'm running navigation laptop and cellphone
  9. Oct 15, 2020 at 10:05 AM
    nd4spdbh
    SoCal
    Built in USB (assuming for the stock headunit) will only do 2.5w (500mah @ 5v). Laptop, are you using a specific 12v charger for the laptop? or inverter to standard wall charger?
  10. Oct 15, 2020 at 10:05 AM
    Bodyguard89
    Montana
    2010 TRD OR DCSB
    When you get the USB cigarette port adaptor, make sure you get the 4 amp ones or at least one of the USB plugins has the 4 amp (or something like 30 watt, forget how they are marked), same power supply needed for most tablets not the lower power one generally for iPods and phones.
    Gunshot-6A likes this.
  11. Oct 15, 2020 at 10:32 AM
    Boco10
    ADK
    Ok. Where can i pick up a 200w inverter?
  12. Oct 15, 2020 at 3:58 PM
    Toyota3b
    Toyota3b Member
  13. Oct 15, 2020 at 5:44 PM
    Boco10
    ADK
    Thanks everyone. It was a long day at work trying to spray paint outside with a heavy wind advisory. It doesn't help that I am in upstate NY doing this in October. Anyways managed to pick up a small 200w inverter from Tractor Supply. My phone without inverter went from 6 hours for a full charge to 1 hour 10 minutes with inverter. I would say that's a win. I haven't had a chance run navigation, phone, laptop, and radar but will do a test run tomorrow. I already have a large battery/jumper pack and can charge now charge it fast with out a generator. I should be able to watch all the cat videos I want while in the desert or on the road.. Thanks again.
    Bodyguard89 and spitdog like this.
  14. Oct 15, 2020 at 7:38 PM
    potstech
    potstech Well-Known Member
    Midlothian, Va
    2013 DCLB
    Unless you have a true sine wave inverter it may not charge your laptop. I used to work on law enforcement laptops and I don't know how many laptops were brought to us saying they would not charge. After asking if they were using an inverter the problem was quickly discovered. Test it out at home before leaving on a trip.
    Bodyguard89 and Boco10[OP] like this.
