Charvonia Design Bed Tie-Down Anchors
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by Charvonia Design, Apr 29, 2021.
  1. Sep 30, 2021 at 1:39 PM
    #121
    vecdran
    vecdran Barely-Known Member
    Jeremy
    Kirkland, WA
    2020 TRD Pro Super White 6MT
    Financial Black Hole
    As long as the camming surface is a flat circle underneath the cam, you should be able to orient it any way you want, barring interference with the tie-down itself.
    Only real complication I could see is material selection for the cam assembly. Aluminum is too soft. All of the scope mounts I have ever seen use aluminum for the body, but steel for the camming materials, include the surface the cam tensions against. I'm thinking for ease of machining and not having to work with inserts or some such nonsense, the whole thing should just be made of steel. Though I suppose it wouldn't be terribly hard to mill a countersunk hole in the aluminum tie down, then friction fit a steel insert for the camming surface.
    Normal steel would mean no fancy anodizing. Paint would just chip, so nitriding would probably be the best route. Unless you went stainless and did heat tempering for color options...
    Starting to sound like $350 per tie-down. Probably easier to just widen the dimensions of the mounting area, cut a relief, and use some spin on knobs. :rofl:
    daveeasa[QUOTED] and Bertw192 like this.
  2. Sep 30, 2021 at 4:45 PM
    #122
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Anodized aluminum is pretty chip resistant. I don’t think these have to be handling super strong stresses. Just enough to anchor the T nuts in place.
  3. Oct 3, 2021 at 6:04 PM
    #123
    Charvonia Design
    Charvonia Design [OP] Enthusiast-Owned Small Business Vendor
    Keith
    Huntersville, NC
    2024 TRD Off Road Bronze Oxide
    I sent out an email today announcing the new Rail Tie-Downs. This went out to anyone who has made a purchase or subscribed to the email list.
    Can you guys please let me know if the email came into your inbox or if it went into spam?
  4. Oct 3, 2021 at 6:05 PM
    #124
    Broadrunner
    Broadrunner Well-Known Member
    The email came straight to my inbox
  5. Oct 3, 2021 at 6:23 PM
    #125
    TRD Larry
    TRD Larry trd larry
    Larry
    South Park, PA
    2019 Tacoma Black,Sport,Premium and Tech Package
    Sport pedals,, Magnaflow cat back exhaust system,Kuhmo 275x55x20, Platinum #220 Abyss wheels 20x9.5. Under hood lights, OEM LED cargo bed lights, extra D-rings installed in bed, AC mod, diff. breather mod, OEM LED puddle lights and footwell lights, Homelink mirror, oil catch can, raptor grille lights, replaced chrome grille molding with black molding, tailgate lock/unlock and tailgate opener, console organizer, glove compartment organizer, Caliraised stealth LED light bar, TRD Cold Air Intake, Lighted cup holders, Meso extended fuse cover, Meso stage 1 tail lights, Meso switch panel, Door bowl lights. Anytime front and rear backup camera mod. TRD Pro Rigid fog lights.Door edge guards. TRD Pro shift knob with Boomer's TRD LED light (Red for security, blue for interior), Glass Break Sensor, sensor with LED light tied into the security LED light, OEM LED Headlights, Sequential LED Turn Signals.
    I got it.
    Charvonia Design[OP] likes this.
  6. Oct 3, 2021 at 7:31 PM
    #126
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    Do you have a picture of the T nut used? Wondering if it’s slide in or if it’s camed so when you undo it, it pulls out.
  7. Oct 3, 2021 at 7:50 PM
    #127
    Charvonia Design
    Keith
    Huntersville, NC
    It’s a machined threaded plate that slides in.
  8. Oct 4, 2021 at 10:19 AM
    #128
    Charvonia Design
    Keith
    Huntersville, NC
    It’s looking like a thumb screw type knob is the best quick release option. What do you guys think?
    vecdran likes this.
  9. Oct 4, 2021 at 11:20 AM
    #129
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    It will be tough to balance the size... big enough that you can break it loose by hand, but small enough to not be in the way.
    But assuming you find that balance, I'll be a buyer.
    If you use the same thread size as the factory rail hooks... could we scavenge the rail plate, so it's drop in?
  10. Oct 4, 2021 at 4:18 PM
    #130
    Charvonia Design
    Keith
    Huntersville, NC
    The factory anchors don’t use a plate, it’s an integrated bolt with a flat head that tightens against the inside of the rail. This is a complete replacement.
  11. Oct 4, 2021 at 4:25 PM
    #131
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Gotcha... Couldn't remember if this piece was removable or not. Point still stands, it would be nice if it were a drop in.
    Sometimes they use a plate like this, to make it "drop-in" versus sliding in from the end. Basically, rounded corners that allow it to go vertical.
    Also, be sure to make it thick enough that it stands up on it's own. Mobtown used to offer thin (3/16"?) plates and they'd fall to the back of the rail and you couldn't get the bolt to engage. It was very frustrating to use.
  12. Oct 4, 2021 at 4:40 PM
    #132
    Charvonia Design
    Keith
    Huntersville, NC
    Appreciate your insights. The current design uses a 1/4” thick aluminum plate. I did this for maximum contact area and strength versus the stock parts. Installation on the side rails is easy, you just remove the plastic cap on the end and slide in the loosely assembled Tie-Down Anchor. If you have the front (header) rail it will need to be unbolted to install these the first time. I always used mine on the sides, not sure how others use them though.
    VicNic3 and Bertw192[QUOTED] like this.
  13. Oct 4, 2021 at 4:41 PM
    #133
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    The issue I've run into with sliding in accessories is that they might not get past bed bars, racks, etc... Just trying to make suggestions that maximize your market.
  14. Oct 4, 2021 at 5:05 PM
    #134
    VicNic3
    VicNic3 Well-Known Member
    GA
    2018 Toyota Tacoma Sport 4x4 DCSB Silver Sky Metallic
    Got the email to my inbox
  15. Oct 4, 2021 at 5:39 PM
    #135
    Tacodog
    Tacodog Well-Known Member
    Ron
    Renton, Wa.
    ‘19 TRD offroad DCSB Cement
    Icon stage 1, Icon upper control arms, 17” Fuel wheels,Ridge Grapplers, TRD exhaust, leather interior.
    Sliding them in would require me to disconnect my canopy tie down points. F8C9C99C-F171-4D58-93DD-3D57927942B8.jpg
    Bertw192 likes this.
  16. Oct 4, 2021 at 7:32 PM
    #136
    RoostrC0gburn
    RoostrC0gburn Well-Known Member
    Oregon
    2017 Super White DCLB TRD Sport 4x4
    they're just t-nuts, right? cant you just twist them in the rail? why would you have to slide them all the way in from the end?
  17. Oct 4, 2021 at 9:00 PM
    #137
    Tacodog
    Ron
    Renton, Wa.
    The canopy mounts are not t nuts. The clamps need to slide out the ends.
  18. Oct 4, 2021 at 9:05 PM
    #138
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Sounds like the design won't fit through the face of the rail... see above quote.
  19. Oct 21, 2021 at 4:39 PM
    #139
    Formidable
    Formidable Well-Known Member
    2017 TRD PRO 6MT
    Any updates? Placed my order on Oct 4th for two sets of red tie downs and one set of red rail tie downs.
  20. Oct 21, 2021 at 5:08 PM
    #140
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Your nut sketch looks like m-loc nuts for gun hand guards. Same design just way smaller.
    Bertw192[QUOTED] likes this.
