Chase racks & roll bars for 3rd gen tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by White_Cali_taco_129, Jun 12, 2021.
  1. Jun 12, 2021 at 7:51 PM
    White_Cali_taco_129
    White_Cali_taco_129 [OP] New Member
    2020 white tacoma trd sport
    33” tires dv8 reinforced bumper w/led light bar
    I am wondering if I should add either a roll bar or chase rack on the bed of my tacoma. I’ve seen a few go by in my area but all were on short bed Tacoma’s and didn’t look as good as I thought. Any chase racks that are appealing to the eye that won’t break the bank?
  2. Jun 12, 2021 at 8:00 PM
    Hercanstein
    Hercanstein Well-Known Member
    Bryan
    State of Jefferson
    1999 2.7 SR5 4x4 5MT XC, 2020 3.5 TRD Sport 4x4 6MT AC
    ('99) Offset Aluminium Wheels, 31" BFG All-Terrains, Bushwacker Fender Flares, Window and Hood Wind Deflectors ('20) Stock
  3. Jun 13, 2021 at 5:25 AM
    SilverSkyTRD
    SilverSkyTRD Well-Known Member
    rather than respond with a weird emoji... I'll say, yea I too would be interested to see if anyone has some good looking options for an access cab.
  4. Jun 13, 2021 at 5:27 AM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
  5. Jun 14, 2021 at 12:27 PM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 1999 Corvette 6MT
    Building a Broja
    Here are the bolt-in options I've personally had.
    Black Horse Off-Road
    This was the RB-TOTASS bar, not their universal (though I don't know if it matters, as I think their universal has the same mounts). I wanted the RB-TOTAB one which came factory powdercoated black, but when I was purchasing, they only had the stainless one available. Mine is (poorly) painted with a rattlecan bedliner. It's held up through two spring-summer-falls, but I pull it off for the winter. There are absolutely no instructions with this bar, so I had to get creative on how to mount it, but it utilizes the factory rail system and screws for the rail system. IIRC I use the bolt on a T-nut (described more below on the N-Fab one) for the front mount and then one of the bed rail bolts for the rear.
    [​IMG]IMG_2566 by Mike M, on Flickr
    [​IMG]IMG_2575 by Mike M, on Flickr
    [​IMG]IMG_1804 by Mike M, on Flickr
    N-Fab
    I got this while N-Fab was still selling these exclusively on the T-Force trucks in the Southern US. I had to send a check and couldn't buy it off their website. It was an adventure. I originally bought it for my 2013 AcessCab. I had custom mounts made by N-Fab to fit the bed rail system. This bar uses the front rail bolts and the side rail bolts to secure. It should use the a bed rail bolt for the rear, but due to the AccessCab having bolts in the different locations, I had a bolt on a T-nut designed to work. It was quite sturdy. When I mounted it on my 2016, I found the tubing to be too small for the heft of the Double Cab.
    [​IMG]Picture2 038 by Mike M, on Flickr
    [​IMG]Pic-1 by Mike M, on Flickr
    Test fitted to my 2016 Double Cab
    [​IMG]IMG_0590[2454992]-edit by Mike M, on Flickr
    [​IMG]IMG_0587[2454990] by Mike M, on Flickr
    [​IMG]IMG_0588[2454991] by Mike M, on Flickr
    I liked the added heft of the thicker bars of the Black Horse. I don't love the horizontal pieces on the bars, nor do I like the horizontal piece across the back window but at some point I'll wire up a set of rear-facing cubes. I've done a bunch of pre-wiring but I haven't completed it.
    Your other options if you don't like these are Vanguard which is similar design with some extra doodads or the GoRhino bar, which admittedly like more than my Black Horse bar, but it requires drilling the bedsides and installing a rivnut, which was a non-starter for me.
    I believe Vanguard and Blackhorse also make other designs that have more tubing along the bed rails, but this is the "classic" rollbar design.
  6. Jun 14, 2021 at 12:43 PM
    slowpoke16taco
    slowpoke16taco Well-Known Member
    Jayson
    SoCal
    2016 MGM TRDOR DCSB
    Stock, but not stock (but stock)
  7. Jun 14, 2021 at 12:46 PM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    These are almost as bad as push bars!.
    YMMPRO and jeremy5000 like this.
  8. Jun 14, 2021 at 4:13 PM
    JEFFRPM
    JEFFRPM Well-Known Member
    Jeff
    2018 inferno Double cab long bed 4x4
    17 x 8.5 KMC wheels, yokohama 285-70-17 geolander, 3" lift, 800 watts of alpine, leer shell, front & rear cloud cameras,
    Looks like the 70's all over again
  9. Jun 15, 2021 at 5:05 AM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
  10. Jun 15, 2021 at 8:14 AM
    SilverSkyTRD
    how many more people will reply to this thread just with a popcorn emoji? Are people doing that because they're interested or thinking their being witty? It's gotta be the most used emoji on this forum(read overused).
  11. Jun 15, 2021 at 8:20 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    :popcorn::popcorn::popcorn::sandwich::popcorn::popcorn::popcorn::sandwich::broccoli::dancingbacon::popcorn::popcorn::popcorn:
  12. Jun 15, 2021 at 8:23 AM
    Kilo Charlie
    Kilo Charlie I have lost my way
    Iowa
    2017 Inferno Off Road
  13. Jun 15, 2021 at 8:29 AM
    averagejp
    averagejp Well-Known Member
    2005 Black Tacoma Extended Cab
    Work in progress
    OP,
    Good luck in your search. I offer no emojis. I thought the whole point of this forum was to build community by being helpful. But I have been told I am old fashioned that way. :)
    I must admit that I don't know the purpose of the chase bars or the roll bars. Are they purely aesthetic? What is the function that they provide that you are looking for?
    In any case, the folks at Extreme Terrain have quite a few options on their site for Tacomas. Here is a link. Note. I am only linking to this because they have a wide selection. I have heard people who order from them have trouble (I have not ordered so I have no personal experience). See if this helps gives you some ideas:
    https://www.extremeterrain.com/2016...V3OKGCh1keQKCEAAYAiAAEgIXvPD_BwE&gclsrc=aw.ds
    I have seen a number of people in my area with the BackRack. Perhaps this is what you were looking for. I get the use of these -- they keep stuff in the bed from shifting forward and crushing the rear window, etc.:
    https://www.backrack.com
  14. Jun 15, 2021 at 9:42 AM
    MikeyMcFly
    I'm a Masshole
    Building a Broja
    Any of the ones I had on my 1993, 2013 or 2016 were strictly ornamental and it didn’t phase me in the slightest. I love my stupid “roll” bar no matter what anyone else thinks of it.
    YF_Ryan and averagejp[QUOTED] like this.
  15. Jun 15, 2021 at 9:44 AM
    averagejp
    Work in progress
    No judgement here ... ! :)
    MikeyMcFly[QUOTED] likes this.
  16. Jun 15, 2021 at 11:18 AM
    Kev250R
    Kev250R Well-Known Member
    Kevin
    Orange, So.Cal.
    2020 Tacoma TRD Off-Road 6MT
    Floor mats, junk in center console
    If my plans didn’t include adding a shell to my truck I’d be interested in one. In my area I see a ton of Taco’s and get tired of them all looking the same. A retro-looking roll bar would be a nice way to stand-out a little.
  17. Jun 15, 2021 at 11:24 AM
    charliehex
    charliehex I belong in the dirt.
    Charlie
    Phoenix, AZ
    2021 Barcelona Red TRD OR DCSB
    285/70/17C BFG All Terrain TA KO2 Method 701 - Bronze 3”F/1"R Spacer Lift Sprint Booster MESO: Gasshole, Map Lights, Sequential Turn Signals Rough Country: Speedometer Calibrator, F/R Seat Covers R4T: Tail Gate Remote Rago: Center Console Molle Panel sPOD: Switch Controller Lamin-x: Amber Fog Light Covers ARB: Twin Compressor Slee Off Road: ARB Twin Compressor Mount Expedition Essentials: 3TPAM Accessory Mount RAM Mounts: Short, Long, Long arm, GoPro Mount
  18. Jun 15, 2021 at 11:25 AM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    @MikeyMcFly - That looks pretty awesome, man. This one gets my vote if @White_Cali_taco_129 needs a bar.
    ALSO: obligatory sitting back to watch popcorn Emoji
    :popcorn:
    MikeyMcFly likes this.
  19. Jun 15, 2021 at 11:28 AM
    Rebelman21
    Rebelman21 Well-Known Member
    Cleveland
    2021 SR5 DCSB Super White
    None yet, several planned
    They aren't for everyone I'm sure, but I think they look good, at least on the 3rd gens.
  20. Jun 15, 2021 at 11:29 AM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
