Chasing a Highway Speed Vibration Problem
Discussion in '1st Gen. Tacomas (1995-2004)' started by Alderleet, Sep 20, 2013.
  1. Nov 5, 2013 at 12:39 PM
    #41
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    One more thought. Have you tried a short drive with the rear half of the shaft removed (in 4wd) just to see if anything changes?
    I once had a squeak (no vibe) that happened only at 3K engine rpm, in any gear, 2 or 4wd, hi or lo range. It was a nick on one of the slip joint splines. How it got there and why it was engine rpm specific, beats the heck out of me. I filed it off, painted the splines with grease and it's quiet as a church mouse.:confused:
  2. Nov 5, 2013 at 12:55 PM
    #42
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    So toss a 3* shim under the leaf ?
  3. Nov 5, 2013 at 2:33 PM
    #43
    Alderleet
    Alderleet [OP] Ace of Spades
    Nick
    Salty Hell
    '00 Acc Cab TRD 4x4
    I'm having the shaft balanced, and angles rechecked by a machine shop that also does auto repair. I'll have some rear axle shims machined for the correct angle needed.
    Tom Woods does not re-balance driveshafts that aren't theirs... That's just silly.
  4. Nov 7, 2013 at 12:00 PM
    #44
    Alderleet
    Nick
    Salty Hell
    '00 Acc Cab TRD 4x4
    Got the driveshaft back, and 2* shims installed.
    Done Son.
    All the shake is gone. No more horrid ass end shake.
    The old german dude at a local machine shop balanced the shaft, and made sure everything was in phase. He changed the weights, and re-welded them all.
    He made sure all of it was perfectly in phase, and made divots in all the steel components so i can always re-align it, if/when i replace u-joints and carrier bearing again.
    Its baby smooth on the highway again. I took it up to 90mph, and it cruised smoothly.
    There we go, my adventures chasing my own tail are over. all is good. :)
  5. Nov 7, 2013 at 12:06 PM
    #45
    Bennett707
    Oregon
    Hmmm... best way to find degree of shim needed?
  6. Nov 7, 2013 at 12:18 PM
    #46
    Alderleet
    Nick
    Salty Hell
    '00 Acc Cab TRD 4x4
    Thats the wierd part, The shims made were 2*.
    Somehow a 6* operation angle, and a 2* shim, made the operating angle 2.5*
    6-2=2.5
    Driveline math is retarded. It doesnt make any sense.
    But yes, the machine shop precision made the shims out of 4140 stainless. They also rebalanced the shaft.
    Its perfect again.
  7. Nov 26, 2013 at 2:13 PM
    #47
    Sin
    Sin Well-Known Member
    Superior, Wisconsin
    1996 Tacoma SR5 4x4 excab 3.4
  8. Nov 25, 2015 at 6:26 AM
    #48
    AMartin
    AMartin Well-Known Member
    Andre
    New Brunswick
    2009 TRD sport DCLB
    3" Bilstain lift, Anytime Fog, Skid Plate, Procomp 7036, Cooper STmaxx, Heated Seats, Interior Plugs.
    How bad was the shake? Wen the shakes started was it immediately a bad vibration or did it get worst as speed increased? I have a vibration similar to this however I did get my drive shaft balanced but it didn't help, starting to thing they didn,t do it right.
