Chasing a right pulling vehicle problem
Discussion in '1st Gen. Tacomas (1995-2004)' started by Alderleet, May 23, 2013.
  1. May 23, 2013 at 9:12 AM
    Alderleet
    Alderleet [OP] Ace of Spades
    Nick
    Salty Hell
    '00 Acc Cab TRD 4x4
    I've been trying to hunt down ways to fix my elusive pulling problem. I initially noticed i had pull when i bought it, but it wasnt bad, so i Ignored.
    I added 3 inches of lift. Everything improved a bit, pulling remained and got a bit worse.
    So far, i've spend shit loads of time trying to figure out this problem.
    My fixes thus far:
    New rack and pinion
    Energy suspension bushings (R&P, and sway bar)
    New inner and outer tie rods, both sides
    New upper and lower ball joints
    Road force then lug centric balance
    Alignment (probably done about 10 times)
    upped pressure, lowered pressure, ran door spec too..
    New wheel bearings
    I've tried everything i can think of to make the annoying problem go away.
    New problem (noticed by alignment shop), I've seem to run out of caster.
    How can i fix this once and for all.
  2. May 23, 2013 at 9:21 AM
    AWorthyOpponent
    AWorthyOpponent Member Caught Off Road
    Dan
    Palm Beach County, Florida
    2013 MGM DCLB TRD SPORT 4x4
    TRD Catback Exhaust
    2 wheel alignment or 4?
    Most places will only do the front since the rear is solid axle...they have to make sure they're compensating for rear thrust angle and then the front wheels can be within spec, but cross camber is off and it'll pull...just went through that myself.
    When you get it aligned, was it always at the same place? What kind of printout did they give you?
  3. May 23, 2013 at 11:00 AM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2009 Prerunner TRD AccessCab
    New Navigation DVD/CD/TV/AV/Bluetooth Stereo and seat mod spacers, 1" hubcentric spacers, seat heaters....
    Yeah, check the rear axle housing, sometimes a big hit can 'alter' a few things, throwing it just slightly out of wack, front can be compensated if not that bad, otherwise you have to get the rear axle running true for it all to work again...
  4. May 23, 2013 at 9:10 PM
    Bmack04
    Bmack04 Active Member
    Ohio
    04 DC trd 4x4
    deck plate mod, grey wire mod, 5100s front w/OME 881s, 5100s rear w/wheelers 5 leaf, 265/75R16 Firestone Destination A/Ts
    If you have 3 inches of lift, you will likely need aftermarket Upper Control Arms to get your caster in specs. This is common with 3" or more lift in tacomas. Did you try cross rotating your tires to see if it changed anything? Does the pull change at all when you are braking?
  5. May 23, 2013 at 10:49 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    Did you check the calipers? Toyota 4 piston calipers are pretty well known for freezing up and dragging
  6. May 23, 2013 at 11:18 PM
    CUtacomaTIGER
    CUtacomaTIGER Unprofessional Driver
    San Diego
    '01 4X4 SR5 Chrome Stepside
    Black Wheels Tow Hitch w/4 Pin Weathertech Floor Mats Flowmaster Deck Plate Mod Window Tint Rear Diff Breather Mod Blacked out Badges Window Rain Guards Bed Liner
    Well at least you basically have a new front end with all those parts you've replaced :D
  7. May 24, 2013 at 6:41 AM
    brs127s
    brs127s Well-Known Member
    O'Fallon, MO
    04 D-Cab 4x4 Limited TRD
    TRD Headers, Aero Turbine AT2525XL Deckplate Mod, TRD tranny cooler, King Coilovers, LR UCAs, Alcan 5 Leaf springs and Bilstein 5100s, Shrockworks front bumper, CBI rear bumper.
    Check your rear brakes also. Back in my tire shop days, if it pulled to the right, it ususally meant the left rear brake was tighter than the right, and vice versa if it pulls to the left. I know that sounds crazy, but it is true.
  8. May 24, 2013 at 9:56 AM
    koco
    koco Well-Known Member
    Bay Area Ca.
    '01 Taco
    Around $26,000 worth of unleaded in the fuel tank.
    I know you said the alignment has been adjusted, but was the caster adjustment made? Sometimes the alignment tech will just do toe and camber and call it a day. It sounds ridiculous, but it happens a lot. If the caster is off, one wheel is touching the ground further back than the other one, and will cause a pull.
    Sometimes it takes a hot shot alignment guy to do it properly.
